Fan won't come on???
My cooling fan on my ef(b16 swap) won't come on. I pulled the fan out and checked to see if it ran and it did. The 15 amp fuse located on the passenger side shock tower is fine but I still replaced it with a new one. Is there a fan switch on these motors? I looked for it in the rad but there's nothing there.
it's on the t-stat housing, if it is plugged in and it still won't run unplug it and jump the 2 wires. if it runs replace the switch. if it don't check your wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Automotiveone »</TD></TR><TR><TD CLASS="quote">IF all else fails,put a switch on it..my mom did the same to his and never gave him a problem since.</TD></TR></TABLE>
Your MOM did it to HIS?
ok thanks! wil try it out tomorrow.
Yeah I was thinking of doing that if I can't figure out the problem.
