whats wrong with my clutch
Old Jan 16, 2005 | 03:27 PM
streetjdm's Avatar
Default whats wrong with my clutch
sup guys...yesterday i pulled into my garage and it sounded like my clutch was touching something like if its not fully disengaged....but when i push the clutch pedal in you hear it stop...but once you let go then it does it again...if any one knows what this is or has had this problem them please let me know
thanks in advance
jafo
Old Jan 16, 2005 | 03:29 PM
Bspec18's Avatar
Default Re: whats wrong with my clutch (streetjdm)
I doubt its your clutch, just may be your throw-out bearing
Old Jan 16, 2005 | 03:56 PM
tnord's Avatar
i've had a couple cars that made noise when the clutch pedal was released in neutral, but not when the pedal was depressed. one was a 98 nissan 240sx, and the other is my 95 GSR. both had new clutches, throwout bearings, and pilot bushings installed. i can't really tell you what causes it, but it never really caused any problems for me.
Old Jan 16, 2005 | 05:21 PM
six_speed's Avatar
~noise on all the time w/ clutch unpress- input shaft bearing (inde the transmission)(new mtf might help cure the noise for a little bit
~noise only when the clutch is press -throwout bearing
Old Jan 16, 2005 | 05:31 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (Humping_dragon)
Could be a few things. First.....what car do you have? You probably have an Integra due to you posting in this forum, but what year? Cable? Hydro?
Could be something as simple as adjusting the cable, or something as complicated as a fucked up transmission. Give us more details.
Old Jan 17, 2005 | 03:20 PM
streetjdm's Avatar
Default Re: (shamoo)
well i have a 95 gsr w/ a exedy clutch new throwout bearing and pressure plate....this morning as i closed my garage i heard the noise from outside like a hising noise and it stoped on its own the car was in neutral no clutch pressed....and when it does it if i press the clutch it goes away
Solstic
Jun 13, 2012 11:34 AM
htwitr01
Jul 3, 2010 01:54 PM
jbsmith
Aug 29, 2005 12:21 AM
Mikey
Jul 5, 2003 09:52 PM
95GS-R
Jan 18, 2002 01:22 PM
