which is tach signal/tach wire - on distributor (obd-0) b18b
what color is the tach signal wire on an obd0 b18b distributor? there are two plugs, one with 2 wires and another w/ nine. I need to know for a vafc hookup in a 2nd gen crx with an obd0 b18. The wiring harness is a disaster, so the signal won't be coming from there. It's for a friend, thanks for the help.
pop your hood ... there is a bundle of wires near the firewall on the drivers side .. in that bundle there is a blue wire that goes into a connector but does not go past the connector (youll know it when you see it) just unplug and connect and there you go
ozzyman
Sep 29, 2003 01:39 AM
ozzyman
