oil in the spark plug cylinders.
Old Jan 16, 2005 | 01:23 PM
cxVtecC1's Avatar
Default oil in the spark plug cylinders.
motor seems to be running ok and the dip-stick reads normal oil level ive burned about 1 qt in 3 weeks, were or what could be causing oil to leek into were my spark plugs go???? please help,Also the oils in the #1 cylinders plug space is more than any other whats going on here???
Old Jan 16, 2005 | 01:30 PM
jason190's Avatar
Default Re: oil in the spark plug cylinders. (cxVtecC1)
There are pretty much 2 ways it could happen...... 1. is the valve's and 2.the rings(if you did a leak down test it should be able to tell you, the rings)
Or do you mean on the porclen part of the spark plug? If that is the case then there is gaskets for each one of the spark plugs on the valve cover that could be your problem.
Old Jan 16, 2005 | 01:47 PM
cxVtecC1's Avatar
Default Re: oil in the spark plug cylinders. (jason190)
I just recently put the motor back together and i do need a valve adjustment could this be a cause and if i took the plug out would the oil leaking in affect anything or just burn away.
though your second thought might also be why, but i did put new ones in maybe they didnt set right, Any more thoughts??
Old Jan 16, 2005 | 02:38 PM
cstay's Avatar
oil is getting through the valve cover gasket
Old Jan 16, 2005 | 03:30 PM
mmuller's Avatar
Mad Scientist
Default Re: oil in the spark plug cylinders. (cstay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstay &raquo;</TD></TR><TR><TD CLASS="quote">oil is getting through the valve cover gasket</TD></TR></TABLE>
Old Jan 16, 2005 | 04:12 PM
86si's Avatar
sounds like your spark plug o-rings in the V/C are leaking
Old Jan 16, 2005 | 04:49 PM
B20TDC2's Avatar
Default Re: oil in the spark plug cylinders. (86si)
you need tube seals ive seen it happen on high mileage cars
Old Jan 16, 2005 | 05:00 PM
cxVtecC1's Avatar
Default Re: oil in the spark plug cylinders. (B20TDC2)
thanks everyone
mafia
Mar 26, 2010 10:13 PM
EG6_978
Sep 13, 2008 02:37 PM
aWeimaraner
Jan 25, 2008 10:52 AM
premo_si
Jan 23, 2008 08:57 PM
matryx
Dec 15, 2007 01:18 PM
