Engine only firing on 3 cyl
Old Jan 16, 2005 | 10:50 AM
.David's Avatar
Default Engine only firing on 3 cyl
so I was coming from a friends house today, I was going rather fast on the highway, and all of a sudden I felt my car kind of studder, EGTs went really low, and it started to sound like a Harley (one of the cylinders was missing) but once I got over 4-5k rpm it would try to start firing again (it would pull but cut out 2 or 3 times to redline) This isn't the first time this has happened though, it has had this problem for about a month now, but it used to last only a few seconds, and it got progressively worse until now it hardly works at all.
I checked its compression and its +-3 in every cyl, but the #3 spark plugs electrode is black, while all the others are tan. Anybody have an idea on what it could be? What should I check for?
TIA
Old Jan 16, 2005 | 01:45 PM
jason190's Avatar
Default Re: Engine only firing on 3 cyl (TurboDaveR)
It sound's like the rotor is shot in your distributor or the cap either way I think it is a combo when you go and buy it. Or that is the maintance suggestion to change the cap and rotor at the same time. But that sounds like the problem.
Old Jan 16, 2005 | 02:10 PM
.David's Avatar
hmm, I hope your wrong, lol
I got new gas and put some injector cleaner in there, im just gonna let it idle for a while...it sounds a little cleaner so hopefully that will fix it
Old Jan 16, 2005 | 03:36 PM
.David's Avatar
nope that wasn't it, lol
could it be ignition timing?
Old Jan 16, 2005 | 03:46 PM
Bspec18's Avatar
Default Re: (TurboDaveR)
any CEL ? if its 71,72,73,74 your misfiring. I would recommend a new Dist car and rotor its only like $20bucks. Are your wires in good conditions ? also when was the last time you changed your spark plugs?
Old Jan 16, 2005 | 04:47 PM
.David's Avatar
no CEL. I changed the spark plugs and checked for spark. So I know thats not a problem
Old Jan 16, 2005 | 07:29 PM
Bspec18's Avatar
then do the cap and rotor
Old Jan 16, 2005 | 07:43 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Bspec18)
do a leak down. COuld be a faulty injector or wiring somewhere also. COuld be a burnt valve, could be a few things
Old Jan 16, 2005 | 09:49 PM
ReV LiMiT's Avatar
Default Re: (Evs-One)
try the wires, becuase it sounds like the same problem i had in my camry. as soon as i changed the wires, the problem stopped.
Old Jan 16, 2005 | 10:41 PM
PrettyLude's Avatar
i think its something in the distributor, i. e. cap, rotor, coil or ignitor
Old Jan 16, 2005 | 10:50 PM
clayne's Avatar
Default Re: (9d DA6 TEG)
The problem is your spark plug wires.
I had this exact same problem. Only present when warm and lower in the powerband (i.e. just coming out of a shift).
Replace the plug wires and it will be fixed.
Old Jan 17, 2005 | 08:33 AM
.David's Avatar
how much are plug wires? should I get OEM?
Old Jan 17, 2005 | 09:14 AM
PrettyLude's Avatar
get some oem or ngk wires, wires are around 60-70 bucks
Old Jan 17, 2005 | 10:13 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (PrettyLude)
yes, only oem or NGK
Old Jan 17, 2005 | 02:12 PM
.David's Avatar
I put my dads spark plug wires on mine, and in the process I had to buy new ones anyways, and it didn't fix the problem (do I have bad luck or what?)
im going to mess with the ignition timing a little, and if that doesn't fix it im going to try swapping the stock injectors in there...ill get this thing running sooner or later
Old Jan 17, 2005 | 02:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDaveR &raquo;</TD></TR><TR><TD CLASS="quote"> if that doesn't fix it im going to try swapping the stock injectors in there... </TD></TR></TABLE>
Try swapping the injector from the affected cylinder with another cylinder to see if the problem moves. That would indicate a bad injector.
Old Jan 17, 2005 | 02:23 PM
clayne's Avatar
It's definitely ignition related. Injectors would not cause an issue like the one you're seeing. Injectors are just solenoids with their duty cycle controlled by PWM (i.e. flip connection to ground open or closed for a given period time and frequency). They either flow and max out their flow or they don't. You'd never see a situation where it's crappy at lower rpm but better at higher rpm.
Cap.
Rotor.
Wires.
Plugs.
Knock sensor connection (if you have one).
Compression test.
Old Jan 17, 2005 | 02:44 PM
.David's Avatar
I took the car to redline today and that cyl wouldn't fire the whole way, so what ever the problem is its getting worse. I think I will swap the injector, couldn't hurt.
Old Jan 17, 2005 | 03:28 PM
.David's Avatar
hmm, I took the injectors out, inspected them, put them back in and now it works just fine. Your guess is as good as mine, hopefull it will stay fixed and I wont be forced to buy new injectors
Old Jan 23, 2005 | 08:52 PM
.David's Avatar
for the search buffs...
turns out it wasn't the injector, one of the injector wires that was going into my resistor box broke off in the head shrink.
DailyGrinderEJ8
Oct 3, 2014 06:14 PM
platinum00
Jul 26, 2009 06:31 PM
Tee Jay
19
Nov 15, 2004 10:06 PM
girlieracerk
Dec 18, 2003 10:12 PM
