gs-r head removal
Old Jan 10, 2002 | 08:33 PM
B_CRUZ!'s Avatar
Default gs-r head removal
i bought a chilton's and it sucks. is there a website that shows exactly which bolts to remove so i can remove the head? also is there a way to remove the head with the valves and cam assembly still intact. i have a lot of time to kill tonight since it is my day off tommorow and i just want to see if there is anything is messed up with the motor i bought.
THANX IN ADVANCE!!!
Old Jan 10, 2002 | 10:24 PM
Kataku2K3's Avatar
Default Re: gs-r head removal (initial_B)
There is no way to keep the cams in and take off the head since the head bolt lie under the cams. However the rest of the valvetrain can stay on while the head is being pulled off. It's really not that hard to remove the head. Go to C-Speedracing.com then go to how to you may be able to find some info on their motor build ups that can help you. I don't think that they have an actual topic that shows how to remove the head step by step but there's a lot of **** on there that i know could probably help. Good luck.
Old Jan 10, 2002 | 10:49 PM
B_CRUZ!'s Avatar
Default Re: gs-r head removal (JDMspecEG6)
thanks
bboyndamake
Sep 6, 2013 06:31 PM
oldskoolaccord
Feb 18, 2009 06:11 PM
91preyludesi
Nov 18, 2005 07:21 AM
Firestarter
Nov 5, 2005 01:30 PM
