Slight grinding/scrapping while turning
Old Jan 16, 2005 | 09:01 AM
cdntegintx's Avatar
Default Slight grinding/scrapping while turning
Every time I turn ever so slightly to the right, I hear this slight growling, like a grinding sound coming from the left front of the car. Has anyone ever had this problem?
Old Jan 16, 2005 | 09:04 AM
Tweakmeister's Avatar
Default Re: Slight grinding/scrapping while turning (cdntegintx)
probably the tire hitting the fender liner
Old Jan 16, 2005 | 09:30 AM
cdntegintx's Avatar
Default Re: Slight grinding/scrapping while turning (Tweakmeister)
no, I checked that, its weird, the noise is there as soon as you turn the wheel the least little bit to the right
Old Jan 16, 2005 | 07:07 PM
calxtreme's Avatar
brake shield?
Old Jan 16, 2005 | 08:30 PM
mikestypeRR's Avatar
Default Re: (calxtreme)
if its a growling then its your power steering lots of hondas do that... if its a scrapping and its NOT your fender liner. Then dam I dont know.
Old Jan 17, 2005 | 02:54 AM
cdntegintx's Avatar
Default Re: (mikestypeRR)
I don't think its the power steering cause it only makes a noise while turning right, not when I turn left.
Old Jan 17, 2005 | 05:28 AM
dc2integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdntegintx &raquo;</TD></TR><TR><TD CLASS="quote">Every time I turn ever so slightly to the right, I hear this slight growling, like a grinding sound coming from the left front of the car. Has anyone ever had this problem?</TD></TR></TABLE>
steering knucklezor?!
Old Dec 15, 2007 | 01:14 PM
dohc_profile's Avatar
to OP,,, ever find out wut the problem was? im helping a friend diagnose the same symptoms and this is hte same problem he has, his dopes it when he turns to the left.
Old Dec 15, 2007 | 02:29 PM
1Point8DC2's Avatar
Default Re: Slight grinding/scrapping while turning (dohc_profile)
wheel bearing. mine only made noises when i moved the wheel a little to left. it was my front passanger side bearing.
theguy22
22
Nov 6, 2011 10:58 AM
yesSiReK
11
Nov 21, 2006 11:20 AM
Ibuprofen
Mar 20, 2005 08:50 PM
nver2
Jan 24, 2004 07:11 AM
mrmonk
Nov 17, 2003 10:29 AM
