maintenence required light
Old Jan 16, 2005 | 08:37 AM
eymnewdc4's Avatar
Default maintenence required light
ok so i read on the CEL light sticky thread, i know what a CEL is. but how do i find out what the MAINT REQD light stands for? its kinda bothering me and it just showed up this morning after a hard start cause it was 11* outside when i left.
Old Jan 16, 2005 | 08:41 AM
Audi A4's Avatar
Default Re: maintenence required light (eymnewdc2)
the maintenece light is just a clock man... its goes off after so many miles... its a technique used by acura to get you to bring ur car in to them... u can reach under the right side of the steering wheel under the dash and press and hold the green button untill the light goes off... make sure the car is off and ignition is cut on to accessorys
Old Jan 16, 2005 | 08:46 AM
eymnewdc4's Avatar
Default Re: maintenence required light (DRAG lll INTEGRA)
thanks bro
Old Jan 18, 2005 | 01:06 PM
eymnewdc4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">the maintenece light is just a clock man... its goes off after so many miles... its a technique used by acura to get you to bring ur car in to them... u can reach under the right side of the steering wheel under the dash and press and hold the green button untill the light goes off... make sure the car is off and ignition is cut on to accessorys</TD></TR></TABLE>
i .. ugh, hmm... im not retarded, but i didnt see it. are they all the same? ive got a 95 LS if that helps .... maybe i didnt look hard enough.
Old Jan 18, 2005 | 01:13 PM
purplegsr's Avatar
You can't see it unless you can fit your head between the gas pedal and the bottom of the dash area. Just reach down to the bottom right side of the dash - where your knee would go if driving (if you are looking straight ahead at your steering wheel), and feel around on the edge of the plastic. You should feel a squarish button, hold it in, turn the key to access. and hold it down until the light goes off.
Old Jan 18, 2005 | 01:22 PM
eymnewdc4's Avatar
Default Re: maintenence required light (purplegsr (Exospeed))
Old Jan 18, 2005 | 02:52 PM
Mordeki's Avatar
Abusing my rights one day at a time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) &raquo;</TD></TR><TR><TD CLASS="quote">You can't see it unless you can fit your head between the gas pedal and the bottom of the dash area. Just reach down to the bottom right side of the dash - where your knee would go if driving (if you are looking straight ahead at your steering wheel), and feel around on the edge of the plastic. You should feel a squarish button, hold it in, turn the key to access. and hold it down until the light goes off.</TD></TR></TABLE>
I think it should be blue if that helps
Old Jan 18, 2005 | 03:30 PM
1sikgti's Avatar
I just did this myself with no knowledge of the button was an just tips from other members,I was able to turn it off using the button without even looking.I just reached my hand under the plastic near where my right knee would be when driving.Its a button inside a box,really easy to feel out.
Old Jan 20, 2005 | 04:05 AM
eymnewdc4's Avatar
Default Re: (1sikgti)
had a little neighbor kid climb under my dash and reset it. its all good
Old Jan 20, 2005 | 07:09 AM
DAguyLS's Avatar
my mother has an 03 civic 4d ex, do you think the reset would be the same on that too?
Old Jan 20, 2005 | 07:19 AM
purplegsr's Avatar
Default Re: (slamdLScivic)
Probably similar, they may have some info on http://www.7thgencivic.com or in the Civic forums. They have changed it over the years, in the 90-93 Accords when the maintanance required indicator flipped on, you had to push your key into this little hole to reset it, and earlier civics and integras don't have one at all.
coronadrinker
Sep 27, 2005 03:45 PM
Rick
Jul 4, 2004 08:31 AM
Xymox
Nov 7, 2003 10:00 PM
jamal-188
Sep 11, 2003 09:51 AM
turbolag98
Aug 1, 2003 03:48 PM
