obdII injectors into obdI car?
Old Jan 16, 2005 | 08:14 AM
acurafighter's Avatar
Default obdII injectors into obdI car?
i have been given a set of rc injectors from a friends prelude which is obdII and i was gonna use them on my 95 prelude which is obdI question is, can i use them or is it best to sell em and get obdI injectors? Any help would be great
Old Jan 16, 2005 | 09:23 AM
prelittlelude's Avatar
Default Re: obdII injectors into obdI car? (acurafighter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurafighter &raquo;</TD></TR><TR><TD CLASS="quote">i have been given a set of rc injectors from a friends prelude which is obdII and i was gonna use them on my 95 prelude which is obdI question is, can i use them or is it best to sell em and get obdI injectors? Any help would be great </TD></TR></TABLE>
if you change the injector clips on your prelude you can use them, but i can't remember right now if the 5th gen has an injector resister pack , but if it doesn't then you have to not use the resistor pack in the 4th gen.
Old Jan 16, 2005 | 09:32 AM
showbiz's Avatar
Default Re: obdII injectors into obdI car? (prelittlelude)
no injector resister box on 5th gens w/ saturated OBD2 injectors
Old Jan 16, 2005 | 09:35 AM
satan_srv's Avatar
Injectors are not OBDI or OBDII. They are A1 vs. A4. They OBDII 96 H22A1 uses the same injectors as the 95 OBDI H22A1.
Old Jan 16, 2005 | 02:00 PM
Default Re: obdII injectors into obdI car? (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">Injectors are not OBDI or OBDII. They are A1 vs. A4. They OBDII 96 H22A1 uses the same injectors as the 95 OBDI H22A1.</TD></TR></TABLE>
yeah but there is a difference between the clips of the a4 and the a1,
if they are obd2 injectors then you need the obd2 clips and you need to bypass the resistor pack
Old Jan 16, 2005 | 03:58 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">
if they are obd2 injectors then you need the obd2 clips and you need to bypass the resistor pack</TD></TR></TABLE>
agree on the resistor pack..forgot about the clips though
caliprelude3087
Sep 6, 2004 05:39 PM
youngkow
Apr 2, 2003 11:44 AM
ZoNe_HKS
Feb 14, 2003 03:25 PM
H22ACiViC
Mar 19, 2002 03:58 PM
Turbohatch
Sep 27, 2001 06:12 PM
