No Clutch pressure, searched...
Old Jan 15, 2005 | 08:45 PM
SilverDc2's Avatar
Default No Clutch pressure, searched...
i recently did a 5 speed swap and everything is done except there is no pedal pessure on the clutch, i bled it a lot and nothing,
i replaced my clutch master cylinder, nothing,
i DO though have a custom hydro line its a universal line,
the slave isn't leaking, nothing is leaking...
IF the car is running wont go into gear, it will grind as if i dont have the clutch in,
off its all good....
Modified by SilverDc2 at 5:49 PM 1/16/2005
Old Jan 16, 2005 | 10:59 AM
SilverDc2's Avatar
Default Re: No Clutch pressure, searched... (SilverDc2)
Old Jan 16, 2005 | 11:04 AM
stareatsun's Avatar
The only thing I can think of then is that you did not instal the pressureplate/disc correctly. Check it again.
Old Jan 16, 2005 | 11:11 AM
SilverDc2's Avatar
Default Re: (stareatsun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stareatsun &raquo;</TD></TR><TR><TD CLASS="quote">The only thing I can think of then is that you did not instal the pressureplate/disc correctly. Check it again.</TD></TR></TABLE>
well there's pressure on the pedal but its not enough pressure,
about the pressure plate install? how can you mess up, u just put the clutch disc in align it and put bolts it has no play...
just curious, how can i mess it up?
Old Jan 16, 2005 | 01:00 PM
gsrtxjarrod's Avatar
With the symptoms u give it sounds like a bad clutch disc. Is this a new or used unit because not being able to get it in gear except when its off sounds like a bad clutch
Old Jan 16, 2005 | 04:09 PM
SilverDc2's Avatar
Default Re: No Clutch pressure, searched... (gsrtxjarrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrtxjarrod &raquo;</TD></TR><TR><TD CLASS="quote">With the symptoms u give it sounds like a bad clutch disc. Is this a new or used unit because not being able to get it in gear except when its off sounds like a bad clutch</TD></TR></TABLE>
its brand new clutch, pressureplate, did i install the clutch disc backwards....the hub where the springs is towards the tranny right?? flat side goes to the flywheel
you think it didn't align right?
Old Jan 16, 2005 | 04:29 PM
[626]95-GSR's Avatar
Check slave cylinder again... there could be an internal leak somewhere. If there is an internal leak in the slave/hydro rod.. then there wont adequate pressure in the line.
Could be a bent or broken shift fork. thats the worst case scenario.
Old Jan 16, 2005 | 04:43 PM
SilverDc2's Avatar
Default Re: No Clutch pressure, searched... ([626]95-GSR)
the fork is fine, i inspected it before intsallation, the only thing left is to replace the slave....=/
Old Jan 16, 2005 | 08:05 PM
SilverDc2's Avatar
anybody got anything else?
Old Jan 16, 2005 | 10:04 PM
SilverDc2's Avatar
HELP!!!!
Lasty K
21
Jun 8, 2007 05:05 PM
IgnitionZ05
Dec 8, 2006 11:27 PM
fasterthenmost
Feb 12, 2006 06:48 PM
Nations Sickest CRX
Aug 30, 2005 03:53 PM
civcexcoupeblack
Aug 25, 2003 07:21 PM
