So I finally got my thermal arc wired up and got some gas
Old Jan 15, 2005 | 04:32 PM
underpressure02's Avatar
Default So I finally got my thermal arc wired up and got some gas
I tried welding last night on some scrap metal and all I can say wow this is a hell of a lot harder then I thought it would be. I called B18C1YA and he helped me out a lot but there are so many setting and things I can changed I don't even know what to correct or change to make it better. I am going to take a welding class in feb but until then I am just going to keep on practicing. I rewelded my exhaust seems to be holding and not leaking. I would take some pics but it is really really bad.
For those who are using a thermal arc. What are some good settings to start out on for doing exhaust pipe?
I also tried the pulser but that helped me burn more holes in my test pipes.
Old Jan 15, 2005 | 05:50 PM
turbo gli's Avatar
Default Re: So I finally got my thermal arc wired up and got some gas (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">I tried welding last night on some scrap metal and all I can say wow this is a hell of a lot harder then I thought it would be. I called B18C1YA and he helped me out a lot but there are so many setting and things I can changed I don't even know what to correct or change to make it better. I am going to take a welding class in feb but until then I am just going to keep on practicing. I rewelded my exhaust seems to be holding and not leaking. I would take some pics but it is really really bad.
I also tried the pulser but that helped me burn more holes in my test pipes. </TD></TR></TABLE>
yes another thermal arc-er ..
for 16guage pipe i recently welded a dp .. i had the setings at around 70/54 amps .. pulsing .. 60% and low hz like 10 or 13 so u can see the arc bounce back between the two amp settings ..
once u get the settings donw right .. your gonna love the thermal arc .. its a bit intimidating at first but keep at it
chino2x2x2x
Jun 23, 2007 02:11 PM
eug_34
Apr 30, 2005 11:06 PM
StolenTeg
Oct 31, 2004 01:57 PM
fastS2K
Honda S2000
Sep 11, 2004 03:50 PM
mikehawkBUiLT
30
Aug 20, 2004 12:58 PM
