CEL comes on after installing ITR cams?
Old Jan 15, 2005 | 02:48 PM
vtec69's Avatar
Default CEL comes on after installing ITR cams?
I just finished installing some ITR cams into my gs-r and for some reason I get a CEL after like 10mins of the car running
So i shut down the car and go to check the code and when I put it in acc. the code disappears???
So then i start it and i dont get a code until like 10 mins of running, but once again it disapears after the car is shut down
I am running the p28 with a kenji chip
Has anyone had this problem b4?
thanks
-Brian
Old Jan 15, 2005 | 02:49 PM
You_Get_Vapors
Guest
Posts: n/a
Default Re: CEL comes on after installing ITR cams? (vtec69)
You need to remedy the code.
Old Jan 15, 2005 | 02:51 PM
vtec69's Avatar
Default Re: CEL comes on after installing ITR cams? (You_Get_Vapors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">You need to remedy the code.</TD></TR></TABLE>
How am I suppose to do that when everytime i go to check the code the code goes away?
Old Jan 15, 2005 | 02:55 PM
You_Get_Vapors
Guest
Posts: n/a
It should flash the code then disappear. Fix the code you see and restart.
When the Vtec SLNOId went out on the Gizzer it did the same thing. Fixed that and it went away. Also the cat went out on the Si and same response.
Old Jan 15, 2005 | 02:56 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">It should flash the code then disappear. Fix the code you see and restart.</TD></TR></TABLE>
Yes i do know how to check codes it just doesnt flash cause after i shut the car down the code goes away
Old Jan 15, 2005 | 03:10 PM
You_Get_Vapors
Guest
Posts: n/a
Yeah it will do that. Make sure you have a good connection to the ECU use wiring not a paper clip. It should falsh the code then stop. Look up the code, fix the situation and restart your car. You shouldnt have a code. Codes usually dissapaer after runnning the car for 10min. Then reappear after shut down and start up.
Old Jan 15, 2005 | 03:14 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it will do that. Make sure you have a good connection to the ECU use wiring not a paper clip. It should falsh the code then stop. Look up the code, fix the situation and restart your car. You shouldnt have a code. Codes usually dissapaer after runnning the car for 10min. Then reappear after shut down and start up.</TD></TR></TABLE>
I tried with a paper clip and a piece of wire and samething happened both times?!?!!
Old Jan 15, 2005 | 03:24 PM
You_Get_Vapors
Guest
Posts: n/a
Check your connection.
Old Jan 15, 2005 | 03:25 PM
You_Get_Vapors
Guest
Posts: n/a
I used a peice of copper computer power connector - either red or black?
Old Jan 15, 2005 | 03:26 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">Check your connection.</TD></TR></TABLE>
What connection?
the jumper connection?
or something else
Old Jan 15, 2005 | 03:28 PM
You_Get_Vapors
Guest
Posts: n/a
Yeah the jumper connection.
Old Jan 15, 2005 | 03:34 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the jumper connection.</TD></TR></TABLE>
checked and tried that like 10 times and the connections are good even with 4 different types of wire
Old Jan 15, 2005 | 03:35 PM
You_Get_Vapors
Guest
Posts: n/a
I dunno then man. Good luck.
Old Jan 15, 2005 | 04:09 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">I dunno then man. Good luck.</TD></TR></TABLE>
well thanks for your help anyways
Old Jan 15, 2005 | 05:42 PM
You_Get_Vapors
Guest
Posts: n/a
YW
Old Jan 16, 2005 | 02:11 PM
vtec69's Avatar
anyone else have any ideas why this would be happening?
BTW this is the first time I have ever gotten a CEL
Old Jan 17, 2005 | 08:27 AM
vtec69's Avatar
anybody else out there with this similar problem???
Old Jan 17, 2005 | 08:34 AM
Copy Cat's Avatar
next time you drive let the light blink for a little while, then check it. the same thing happened to my gsr and i couldnt get a code. Then finally i was like **** it, and i let it blink for a while and the light became solid. From that point on i was able to find out what my problem was. Misfire on cylinders 1 & 2 im not implying that your misfiring
Is the car idling fine? driving ok?
Old Jan 17, 2005 | 08:46 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: CEL comes on after installing ITR cams? (CivicFerioViRs)
When the CEL comes on while driving, it should NOT flash. It only flashes when in diagnostic mode, i.e. the diagnostic connector has a jumper wire in it.
Try driving it, and when the CEL comes on, go ahead and jump the diag. connector. Don't turn off the car. Then see what code it flashes out.
Also, if there are no codes stored (CEL not on while idling or driving normally), and you jump the diag. connector, then the CEL should come on steady, and NOT flash. That simply means it is now in diagnostic mode and you can do things like check and adjust ignition timing, etc.
Old Jan 17, 2005 | 09:14 AM
Copy Cat's Avatar
Default Re: CEL comes on after installing ITR cams? (PatrickGSR94)
it can flash when your not in diagnostic mode bro. come to maryland and ill show you
Old Jan 17, 2005 | 09:50 AM
vtec69's Avatar
Next time I go out for a drive I'll try this
As soon as a code pops up ill pull over and not turn the car off and jump the ecu and see if that works cause if that doenst than I really have no idea what to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">When the CEL comes on while driving, it should NOT flash. It only flashes when in diagnostic mode, i.e. the diagnostic connector has a jumper wire in it.
Also, if there are no codes stored (CEL not on while idling or driving normally), and you jump the diag. connector, then the CEL should come on steady, and NOT flash. That simply means it is now in diagnostic mode and you can do things like check and adjust ignition timing, etc.</TD></TR></TABLE>
Old Jan 17, 2005 | 12:18 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioViRs &raquo;</TD></TR><TR><TD CLASS="quote">When the CEL comes on while driving, it should NOT flash. It only flashes when in diagnostic mode, i.e. the diagnostic connector has a jumper wire in it.
it can flash when your not in diagnostic mode bro. come to maryland and ill show you </TD></TR></TABLE>
I don't see why, it's not supposed to work that way. The light is supposed to come on when a code or codes are stored in the memory, and then you have to put the ECU into diagnostic mode to retreive the codes.
At least that's how it works with OBD-1 cars.
Old Jan 17, 2005 | 03:18 PM
Copy Cat's Avatar
Thats what i thought too, but it could be an obd1 thing i dont know. I was told that a blinking cel means catastrophic damage may occur to the motor or it means hardcore misfire. here is the link to the thread i started back in december. vtec 69 you may also want to look at this, but i will tell you right now, that my gsr was driving like crap when i got a blinking cel.
https://honda-tech.com/zerothread?id=1094713
Old Jan 18, 2005 | 09:59 AM
vtec69's Avatar
ok so i finally was able to read the code
it flashes one time really quickly then pauses for like 2 seconds than flashes 9 times reall quick
so does that mean im shooting 2 codes?
and why would they only come on after driving for like 20 miles under normal drivng?
Old Jan 18, 2005 | 05:27 PM
Copy Cat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i finally was able to read the code
and why would they only come on after driving for like 20 miles under normal drivng?</TD></TR></TABLE>
1 O2A - Oxygen sensor #1
and/or
9 CYP - cylinder sensor
