Question?: Can I run a stock USDM 98-01 Type R chip in a 98 GSR w/ a new manifold
Old Jan 15, 2005 | 02:48 PM
You_Get_Vapors
Guest
Posts: n/a
Default Question?: Can I run a stock USDM 98-01 Type R chip in a 98 GSR w/ a new manifold
Can I run a stock USDM 98-01 Type R chip in a 98 GSR w/ a new manifold?
Old Jan 15, 2005 | 03:13 PM
rough_draft's Avatar
you mean type r ecu?
Old Jan 15, 2005 | 03:31 PM
You_Get_Vapors
Guest
Posts: n/a
Default Re: (That vodka That Sprite)
No like a burnt chip from a USDM Type R. Then edited progressively with Uber Data or Hondata.
Old Jan 16, 2005 | 12:18 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: (You_Get_Vapors)
bump
Old Jan 16, 2005 | 12:47 AM
pmed you
Old Jan 16, 2005 | 12:59 AM
dFreezy's Avatar
i hope you're not referring to an eBay "usdm type r" chip are you?
Old Jan 16, 2005 | 01:13 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: (dFreezy)
No I could get a custom chipped ECU but I'd rather start out with the base for a Type R and edit it from there using Uberdata or Hondata then do some dyno tuning later. I'm thinking with a base Type R it should be good for start up and driveablity.
integrasi
Aug 8, 2004 06:59 PM
