92 accord brake problems
recently replaced my brake master cylinder...
bench bled it and put it all back together.
well i went to start to bleed the brakes and reliezed there is no pressure in the brake lines .. no air no fluid nothing is coming out.
both the abs unit and cylinder are full of fluid.
92 honda accord ex. abs
any ideas?
any ideas?
Gravity bleed is the best thing to do; open the front left bleeder and keep the master full. Then when you start getting fluid from the front left, start the bleeding thru the other wheels.
ok i got fluid out of both the front wheels but still no fluid or air is coming out of the two rears. and brakes still feel like there is air in the lines ... which there is since there isn't any fluid coming out.
I'm guessing you didn't bleed it correctly. Try it again. You can disconnect the brake lines at the master cylinder, attach plastic hoses to brake line ports and have someone slowly pump the pedal as you watch to make sure air is completely bled.
dgdarien
Sep 25, 2009 06:25 PM
