Enkei RPF-1 17x7.5, +48 offset heads up!!!!!!!!!
Old Jan 15, 2005 | 01:51 PM
Halo's Avatar
Default Enkei RPF-1 17x7.5, +48 offset heads up!!!!!!!!!
I have been shopping around for some good 17" rims for the street..I finally decided on going with the Enkei RPF-1 rims 17x7.5, 5x114, 48+ offset with 225/45 Falken Azenis sports..Well guess what it doesn't fit..The inside of the rim hits my progress coilover spring perch adapter...So I will try and return them from the shop I bought them from..Are shops usually good about returning stuff like that? It makes no mention of a re-stocking fee? So on our cars it seems the best offset is like a 40-42 offset...Thoughts? Oppinions? Experience? Please chime in
Old Jan 15, 2005 | 02:05 PM
DC5ITR329's Avatar
Default Re: Enkei RPF-1 17x7.5, +48 offset heads up!!!!!!!!! (Halo)
that's to high of an offset. if you have the JDM DC5 R suspension then you can put those on. but on reg rsx suspension 42 offset is good.
Old Jan 15, 2005 | 05:00 PM
Halo's Avatar
Default Re: Enkei RPF-1 17x7.5, +48 offset heads up!!!!!!!!! (aznbo1626)
its an ep3
Old Jan 15, 2005 | 05:02 PM
EtherGhost's Avatar
5 mm spacers
Old Jan 15, 2005 | 06:15 PM
Halo's Avatar
Default Re: Enkei RPF-1 17x7.5, +48 offset heads up!!!!!!!!! (EtherGhost)
I was thinking about that too..Can you get by using the stock studs with a 5mm spacer?
Silspeg6
Apr 2, 2007 05:41 PM
FadeToBlack
Sep 6, 2005 06:03 PM
boostedhonda
Oct 17, 2003 01:51 AM
avs
Jun 11, 2003 09:19 PM
9d9GSR
May 21, 2002 12:53 PM
