DIY Turbo help..
i plan on pieceing together my own T3 setup for my gsr. 2 problems im runing into are, where can i find a downpipe? and also, where can i get all of the charge pipes? thanks alot..
This is an interesting question since usually it's pretty hard to "buy" a DP and IC piping. The reason is that each mainifold and turbo are different on every car and it would be impossible for a manufacturer to stock every kind of compination unless a.) they sell you an entire kit or b.) like full-race or neukin manifold they custom make DP's since you will tell the the flang type and turbo when you order a DP. IC piping is kinda the same way although you can find a set of IC piping you will still need to cutting/ adding more pipe depend on the turbo placement and Intercooler used.
I pieced my own kit together as well and ran into the same problem you did. I read a round a little and decided to make them myself. I have no welding skills nor have done anything like this. But everything was very easy in the end. All I did was buy 2 3" Ubends (DP) and 4 2.5" ubends (IC piping). Then I mocked the turbo to it's spot and marked where I should cut. I then cut away with a sawzall and had all the pieces welded by a local muffler shop. I have never had a problem with my DP or IC piping up to now. Never even blown off a pipe!
Anyway here are the pipes:
Intercooler pipes after being cut:
After the muffler shop welded it all for $35 and it took like 40 minutes:
Another pic of the DP:
GL with whatever you decide
thanks alot for the tips, those turned out great! i guess i will just have to wait for some nice weather and a good day to do it.. one more question is.. where did you get the Flages from, and also where did you get the O2 bung?
(what setup are you running, and do you think running without a cat is better?) [sorry im new to this]
VTEC-DA
Jan 16, 2003 05:05 PM
