Can Anyone tell me where adjust the screw on the end of TB
Old Jan 15, 2005 | 07:46 AM
Kooneryfz450's Avatar
Default Can Anyone tell me where adjust the screw on the end of TB
I purchased a 1999 civic si with b16a and the owner prior has adjusted this screw which I am to beleive is the air mixture screw does anyone know the factory setting on this how many turns out ,I do have a cold air intake and DC sports header with apex cat back exhaust if this matters ?
Old Jan 15, 2005 | 08:02 AM
mmuller's Avatar
Mad Scientist
Default Re: Can Anyone tell me where adjust the screw on the end of TB (Kooneryfz450)
thats for your idle, if your car idles fine dont mess with it
Old Jan 15, 2005 | 08:21 AM
primeredbeast's Avatar
Default Re: Can Anyone tell me where adjust the screw on the end of TB (mmuller)
yep what he said
Old Jan 15, 2005 | 11:48 AM
Default Re: Can Anyone tell me where adjust the screw on the end of TB (primeredbeast)
i only ask because I can see that it has been messed with the car idles I think kindof high at around 1400
Old Jan 15, 2005 | 05:05 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kooneryfz450 &raquo;</TD></TR><TR><TD CLASS="quote">i only ask because I can see that it has been messed with the car idles I think kindof high at around 1400</TD></TR></TABLE>
well if you look directly at the TB it should be almost at the very top(kinda a little bit to the left). you will need a flat-head screwdriver to adjust it and a tachmometer to make sure you are doing it correctly and within factory specs.
Old Jan 15, 2005 | 10:31 PM
engine_runner's Avatar
the screw usually is brass colored on the side of where the intake goes in the tb on the top. adjust rpm to about 700-800 as long as the idle isnt to rough you can go lower.
Old Jan 15, 2005 | 10:34 PM
strsi's Avatar
Default Re: Can Anyone tell me where adjust the screw on the end of TB (engine_runner)
yea, 1400 is pretty high. Just adjsut it with the brass colored screw on the TB. I'd turn it down to about 800 or so.
07siftw
Honda Civic (2006 - 2015)
23
Feb 23, 2008 05:59 PM
sugarloafpkwy
Mar 12, 2006 10:07 AM
kluckerz
Sep 28, 2005 01:40 PM
type Gendy
10
Jul 23, 2004 09:30 AM
ciRcuitJerk
Jul 6, 2003 09:21 PM
