tire mounting machine
Old Jan 14, 2005 | 10:37 PM
vdub08's Avatar
Default tire mounting machine
how the hell do u use one of these.
my buddy has one at his machine shop, but he nor i knows how to use it. i wanna make sure i kno wth im doing before i cut up someone else's new rims
Old Jan 15, 2005 | 11:18 AM
hawaiianbro's Avatar
Default Re: tire mounting machine (tofu9000)
It's called a tireman and if your doing low profile tires you need to make sure you have an extension that pushes the lip of the tire onto the rim or you'll **** up the tires. It's really easy to use.....Is it a snap-on??? I believe they have instructions on there site, under technical information. Not too sure though.
Old Jan 15, 2005 | 12:13 PM
jlacoy82's Avatar
71.192.16.183
Default Re: tire mounting machine (hawaiianbro)
Basic idea is:
-Place rim on
-Lock rim down
-Clean lips/beads on tire/rim
-Press lower bead over rim, using appropriate tool
-Pop upper bead onto rim, using appropriate tool
-Wet beads w/ the soapy water stuff
-"Blast" air into it, and hope the beads seal
-Repeat until tire pops the bead onto wheel
-Unlock, pull off and blow up to pressure!?
I dunno, the mechanic at work used to do it all the time and I'd stand there smokin a butt watching him, never did it myself though.
Old Jan 15, 2005 | 10:38 PM
taz77's Avatar
New User
there are different kinds...
the only two i'm aware of rotates the wheel with a stationary arm and the other is vice versa... stationary wheel and rotary arm...
do u know which kind u have?
Old Jan 15, 2005 | 10:47 PM
vdub08's Avatar
i dont kno, i gotta go to the shop again.
it doesnt sound too complicated. so far it just seems like i just need to get the bead and everything straight and my rims wont get fucked up
Old Jan 16, 2005 | 02:18 PM
taz77's Avatar
New User
Default Re: (tofu9000)
is it like this:
or like this:
Old Jan 18, 2005 | 06:52 AM
acy76's Avatar
Default Re: (taz77)
If it's like the second machine pictured above, I would pay a tire shop to do it. We had one of those things at the shop where I used to work, and any tire under a 65 profile was extremely difficult to mount/dismount. Very likely you will damage your wheels and/or tires, too.. beads can get torn off very easily with one of those machines.
John 07
Mar 23, 2009 07:47 PM
portaman03
May 4, 2007 05:00 AM
sniperslayer
Sep 28, 2004 04:10 PM
metal-x
Jun 20, 2003 08:40 AM
Mr.Rab
Jul 1, 2002 09:05 PM
