valves chattering
Old Jan 14, 2005 | 05:30 PM
96_teck's Avatar
Default valves chattering
i have a gsr head, it has valvesprings and retainers, and am using rs machine stage 3 cams. i am in the process of breaking the motor in, taking it easy for 500-600 miles. the valves were adjusted to
.007 intake/.007 exhaust on these cams, just recently the valves got a little noisy, just wondering if this is normal or do the valves need to be adjusted again. i was going to adjust them this weekend to .007intake/.009 exhaust. so should i just leave it alone, adjust them and what is a good int/exh valve clearance for those cams? this is my first b-series so i need a little feedback from some vets. sorry no cam specs.
Old Jan 14, 2005 | 07:04 PM
1BadCvC's Avatar
Default Re: valves chattering (96_teck)
id go over the valves again to make sure that none somehow got loose. Other than that i got no clue.. gl
Old Jan 15, 2005 | 05:32 AM
SPEED FoRCE's Avatar
go over the valves again, maybe you didnt lock them down well enough after you set it last time.
Boner_Ben
25
Jan 19, 2006 08:05 AM
jdmhondageek
Jan 25, 2002 08:52 PM
3rdGteg
Dec 24, 2001 10:29 AM
ajbones
Jul 10, 2001 02:28 PM
