Messed up Idle problem....No CEL
Old Jan 14, 2005 | 05:13 PM
crexer's Avatar
Default Messed up Idle problem....No CEL
Got my b16 swap in my crx finally done and its got a weird idle. At first It threw code 14 IACV and I realized that it wasnt plugged in. I have cleaned the screen on that valve and the idle still bounces from like 1,000 to 1500 rpms'. NO codes anymore but it still does this. I have bled the coolant system several times and that did seem to bring it down a bit. What about the adjuster screws on the TB? How do you go about adjusting these? What other ideas do you guys think this might be?
Old Jan 14, 2005 | 07:47 PM
crexer's Avatar
Default Re: Messed up Idle problem....No CEL (crexer)
thanks guys....
Old Jan 15, 2005 | 11:14 PM
PrettyLude's Avatar
checked all the vacuums?
Old Jan 15, 2005 | 11:36 PM
Little Rascal's Avatar
Default Re: (PrettyLude)
i would get all the vaccum lines, then next there is a iacv on the back of the bottom left rear of the block, might have to take the throttle body off to see it, to 8mm nuts i think to take the cover off and inside there is a thumb screw thing, turn it clock wise and see if the idle gets better,,,,,but if that is what is causing it, it will only do it when its cold then settle down, if it does it all the time, either a sensor or vaccum lines, u can also do a small check to see if the idle calms down, take the intake tube off and start the car (cold) and place your finger for the idle air passage, if the idle goes down you know its that piece on the back of the block hope this helps
Old Jan 16, 2005 | 08:13 AM
crexer's Avatar
Default Re: (Five0ThreeRepn)
All the vacuum lines have been removed except for the Map sensor and the FPR.....not purge or charcoal canister vacuum lines. I have heard from a few thats its the FITV?
Old Jan 16, 2005 | 02:32 PM
PrettyLude's Avatar
inside your tb there is a small hole put your finger on it to check it
Old Jan 16, 2005 | 02:38 PM
jason190's Avatar
Mine did it all the time. It was the Fast Idle valve on the bottom of the Throttle body. I went through like $150 and finally replaced that. And it lasted like 2 weeks. All the neighbors were complaining. It sucked LOL
Old Jan 19, 2005 | 02:42 PM
SkRiBLaH's Avatar
Default Re: (jason190)
Ok update....the IACV has been cleaned and i took off the FITV and screwed the white plug all the way in. Also I have adjust the throttle screw all the way down and it still idles at 2300 rpms hot or cold. Although it does not fluctuate anymore. Any help on this
Old Jan 19, 2005 | 05:56 PM
PrettyLude's Avatar
try adjusting the throttle cable, might be too tight
Old Jan 20, 2005 | 08:09 AM
crexer's Avatar
you got it ^ That fixed it thanks!
dth0ng69
Nov 11, 2009 09:16 AM
JSR
May 17, 2006 10:27 PM
mafay2
Jul 13, 2005 11:52 AM
crexer
Jan 15, 2005 09:46 PM
RedStarGsr
Jan 7, 2004 12:01 PM
