Car dies when I push in the clutch
Old Jan 14, 2005 | 04:39 PM
devnull's Avatar
Default Car dies when I push in the clutch
So if I'm coming up to a red light and I push in the clutch and RPM's fall below 1000 the car like dies or runs at like 500 rpm. It might slowly come back up but more often it dies. No codes. It's like the IAC doesn't work. And you know usually when you push in the clutch when your rolling the car stays at like 1200 RPM , it doesn't do that either.
What could it be?
94 Stock LS 4 dr.
Old Jan 14, 2005 | 07:07 PM
BACKintheDA's Avatar
Default Re: Car dies when I push in the clutch (qi_doy)
my car had a similiar problem, so i cleaned the throttlebody and that did the trick.
Old Jan 15, 2005 | 06:35 AM
sti99civicsi's Avatar
Mine is doin the same thing right now. I've been told to check the IAC sensor, just haven't got around to it.
Old Jan 15, 2005 | 04:15 PM
devnull's Avatar
So I cleaned the Throttle body and the IAC and it fixed it. Took about 20 minutes. Thanks.
2jz240z
Jun 27, 2005 08:46 PM
nightryder21
Jan 2, 2004 02:11 PM
StudioJDM
Apr 15, 2003 12:48 PM
Tiwe
Sep 9, 2002 03:25 AM
