HELP............................. code P0505
Old Jan 14, 2005 | 01:34 PM
zseeanz's Avatar
Default HELP............................. code P0505
I've been having idle problems for awhile now. The car idles high and bounces around a little bit. I cleaned out the IACV and that didn't help. I also replced the IACV after that. The problem is still there. Anyone have any ideas?
Old Jan 14, 2005 | 05:57 PM
sharky8513's Avatar
Default Re: HELP............................. code P0505 (zseeanz)
i have the same problem....haven't been able to figure out yet..i'll have to keep an eye on this one
Old Jan 14, 2005 | 06:03 PM
zseeanz's Avatar
What about cleaning the ports on my throttle body??
Old Jan 14, 2005 | 06:21 PM
2lua's Avatar
need more info on your car, model, motor.
check tps to see if it at spec.
clean iacv, fitv.
Old Jan 14, 2005 | 06:35 PM
zseeanz's Avatar
Default Re: HELP............................. code P0505 (2lua)
IACV was cleaned, then later replaced with a brand new valve. Motor is a D16y8. How do I check the TPS? What's it suppose to reade?
Old Jan 14, 2005 | 06:55 PM
Relic1's Avatar
TPS is 0.5 volts at idle, 4.5 volts at WOT. check with engine not running but key on. center wire is signal wire.
410ruga
Mar 25, 2014 12:07 AM
h22blklude92
Jun 14, 2011 05:23 PM
got00rice
Dec 30, 2009 12:16 PM
Manny86
Sep 3, 2006 09:27 AM
RCautoworks
Jun 6, 2004 08:48 AM
