where to buy OBD1 plugs and pins
Old Jan 14, 2005 | 11:36 AM
Brian_92GSR's Avatar
New User
Default where to buy OBD1 plugs and pins
I'm looking for a set of OBD1 plugs and the proper pins to rewire my ecu. Does anyone know where I can get these without a huge buy quantity? Or just a part number for the different plugs?
Old Jan 14, 2005 | 12:47 PM
Katman's Avatar
Default Re: where to buy OBD1 plugs and pins (Brian_92GSR)
I have some spare OBD1 ecu plugs w/pins still attached to them.
Which plug or plugs did you need exactly?
Old Jan 14, 2005 | 05:01 PM
New User
Default Re: where to buy OBD1 plugs and pins (K@man)
I have an AEM ECU and quite a messy situation down there. I'd like to relocate the ECU, which will require either extending the wires or even making a whole new engine harness. Maybe all I really need are the pins, and the tool to properly crimp them. I suppose I could reuse the plugs I already have, and just remove the exisiting pins and wires.
Old Jan 15, 2005 | 10:40 AM
Katman's Avatar
ooooo..(scary)....good luck with that!
Old Jan 16, 2005 | 01:10 PM
00000xxx's Avatar
make a really long harness to extend it so you dont have to cut the stock harness.
just a suggestion
Old Jan 16, 2005 | 01:23 PM
hondaguyef's Avatar
Default Re: where to buy OBD1 plugs and pins (ctr610)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr610 &raquo;</TD></TR><TR><TD CLASS="quote">make a really long harness to extend it so you dont have to cut the stock harness.
just a suggestion</TD></TR></TABLE>
A very good one though. . I have a ton OBD1 pins all w/ about 6-8in. of wire on each if you are interested.
Phil
Old Jan 16, 2005 | 06:35 PM
New User
Default Re: where to buy OBD1 plugs and pins (hondaguyef)
I found someone that sells new pins with 6" of 20 gauge wire for 35 cents each. That should work if I can't find just the pins.
Old Jan 17, 2005 | 06:41 AM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian_92GSR &raquo;</TD></TR><TR><TD CLASS="quote">I found someone that sells new pins with 6" of 20 gauge wire for 35 cents each. That should work if I can't find just the pins.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=997093
Good talking with you Brian. The problem is the hand tool isn't the best for the OBD1 pins. I use the pneumatic machine for all my pin termination and it is much stonger and cleaner. I can also provide the pins we discussed with longer wire if needed.
Jason
http://www.JKobdconversionharness.com
sic612
Sep 9, 2008 10:26 AM
JUN.
Mar 28, 2008 06:00 AM
Garrett
Dec 29, 2003 06:43 PM
drunknbass
Nov 28, 2003 07:31 PM
b16aeg6
May 3, 2002 12:26 PM
