ticking valves?
Old Jan 13, 2005 | 10:54 PM
scUba-stEve's Avatar
Default ticking valves?
just rebuilt my motor...i have stainless steel valves, rocket springs/retainers, and crower 402 cams...the valve lash is set at .007in .008ex...just wondering if i should loosen them or what?...the ticking is not very loud...but loud enough to annoy someone...is it just because everything needs to break in and then re-adjust the valves again?...let me know...thanks.
Old Jan 14, 2005 | 07:40 AM
InjectedPerformance's Avatar
We sell parts.
Default Re: ticking valves? (b20vtecTURBOnos)
what temperature was the head when you did the valve lash?
Old Jan 14, 2005 | 03:42 PM
Default Re: ticking valves? (Marty T)
very cold...the head went to the machine shop for about a week and a half, brought it back and did the valve adjustment.
Old Jan 14, 2005 | 03:44 PM
a friend told me that, with stiffer valve springs and bigger cams, that ticking noise is somewhat normal...he said if it's not really really loud, then it should be fine...is this true?
Old Jan 14, 2005 | 03:55 PM
jlacoy82's Avatar
71.192.16.183
Im planning on dealing with valve-ticking when I go big cams and stronger springs. I think its due mostly to the lift/ramping of the cam lobes and not so much the springs, but I'm an idiot so I'm probalby wrong, so just wait for someone to give you the right answer.
crexer
33
Dec 29, 2006 10:04 PM
civicguy
Dec 27, 2001 04:22 PM
