Shoudl I put a Y8 head on my z6?
Old Jan 13, 2005 | 10:51 PM
rasinhell's Avatar
Default Shoudl I put a Y8 head on my z6?
Sup guys i have a Y8 that's fukd but the head is still good. Would i benifit from putting that head onto the z6 that I have?
Also... is teh Y8 tranny better than the z6 tranny?
Old Jan 13, 2005 | 11:09 PM
DRIVENRacing's Avatar
keep the z6, thew y8 manifold will benefit, but from what ive heard the z6 flows a tad better... other than the huge mani that y8s use...
Old Jan 13, 2005 | 11:12 PM
wifesaynogo's Avatar
Default Re: (adSPEED)
no u shouldn't...no real benefit
Old Jan 14, 2005 | 02:48 AM
civic-4-ges's Avatar
Default Re: (wifesaynogo)
Z6 bottom end =more reliable than y8 bottom end. I would go with it, just swap your knock sensor over to the z6 block
Old Jan 14, 2005 | 04:10 AM
rasinhell's Avatar
Default Re: (civic-4-ges)
Do you guys know if the Y8 tranny is beetter than the Z6 one?
Old Jan 14, 2005 | 04:15 AM
HatchEh2's Avatar
Default Re: (roboedar)
dude...its only like 2hp, if that! the y8 has a tad bit higher CR and a square combustion chamber... it really isnt worth the work but if u say:
port, polish, and mill the head then do some modds to it...then it was worth the labor ; ... and the extra 2hp
Old Jan 14, 2005 | 04:16 AM
sockvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roboedar &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys know if the Y8 tranny is beetter than the Z6 one?</TD></TR></TABLE>
nope...i belive its the same gearing and everything
Old Jan 14, 2005 | 04:55 AM
Normworldhero's Avatar
The z6 head will outflow the y8 head. This will benefit you in the future, espescially if you choose to go with a forced induction set up later on, as the intake side of the z6 head does not have the curved split in the tracks that the y8 head does.
Old Jan 14, 2005 | 05:30 AM
Soccerking3000's Avatar
Default Re: (zoomzoom92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoomzoom92 &raquo;</TD></TR><TR><TD CLASS="quote">
nope...i belive its the same gearing and everything</TD></TR></TABLE>
actually a difference is that the shift forks inside the d16z6 tranny are aluminum and are prone to breaking under hard shifting, the y8 tranny has steel shift forks
Old Jan 14, 2005 | 06:38 AM
Mike D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Z6 bottom end =more reliable than y8 bottom end. I would go with it, just swap your knock sensor over to the z6 block</TD></TR></TABLE>
i would love to hear why you think this is true?
even a ported a y8 wont flow as well as a z6. Y8 tranny has stronger shift forks. Same gearing
Mike
Old Jan 14, 2005 | 06:48 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (Mike D)
Echo:
Z6 head &gt; Y8 head
Y8 tranny &gt; Z6 tranny due to shift fork issue.
The Y8 head does rasie CR slightly, but the square chambers are more of an emissions/fuel issue than performance/flow.
Old Jan 14, 2005 | 07:42 AM
jdmjohnny's Avatar
Default Re: Shoudl I put a Y8 head on my z6? (roboedar)
i also heard the y8 head flows better id go with that...
Old Jan 14, 2005 | 07:45 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Shoudl I put a Y8 head on my z6? (jdmjohnny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjohnny &raquo;</TD></TR><TR><TD CLASS="quote">i also heard the y8 head flows better id go with that... </TD></TR></TABLE>
You heard wrong. Try reading the topic dude.
Old Jan 14, 2005 | 07:51 AM
skip.two's Avatar
go with this setup...
Y8 block
Y8 tranny
Z6 head
Y8 intake manifold
the Z6 head flows better than the Y8 head
Y8 intake manifold is better than the Z6 intake manifold
its too early to think of why the Y8 block is better than the Z6 block, so tom chime in.
Y8 tranny has the same gearing as the Z6, but is better than the Z6 tranny
Z6 = aluminum shift forks
Y8 = steel shift forks
Old Jan 14, 2005 | 07:58 AM
ap1amor's Avatar
Default Re: Shoudl I put a Y8 head on my z6? (jL iLLuZiOnz 9)
yea, what they(jL iLLuZiOnz 9 & B18C5-EH2) said.
Old Jan 14, 2005 | 08:01 AM
HatchEh2's Avatar
Default Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike D &raquo;</TD></TR><TR><TD CLASS="quote">
Mike</TD></TR></TABLE>
Bump for that one
Old Jan 14, 2005 | 08:05 AM
HatchEh2's Avatar
Default Re: (HatchEh2)
**** it
go with the B7 head, rig up a **** load of AwEsOmE B1inGy 1iGhTs y0
then everyone on the street driving a geo will wanna race you and trust me, you'll win (by like 3ft.).
Cu2 Den yu0 g0ttz dA h0t WhIp y000!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">go with this setup...
Y8 block
Y8 tranny
Z6 head
Y8 intake manifold
Y8 = steel shift forks</TD></TR></TABLE>
blackhope121
Jul 2, 2007 11:37 AM
Dasavior
May 4, 2004 07:41 AM
LegendLS95
10
Oct 18, 2001 07:45 AM
