TYC Projectors
I'm waiting for my TYC also. Mine is an 01 sedan. How did you put them on? Did you have to remove the bumper? How long did it took you? What about those extra bulbs(fogs)? Anything would help. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T ! N »</TD></TR><TR><TD CLASS="quote"> How did you put them on? Did you have to remove the bumper? How long did it took you? </TD></TR></TABLE>
Yeah you have to remove the bumper. Shouldn't take you any more than an hour, or two.
I don't know if you are talking about the bumper or the housing, so I'll explain both.
You don't need to completely remove the bumper; only the upper part. For the bumper, simply remove a bolt that is located where the fender and bumper meets: next to the wheel. Also remove bolt holding the splash guard to the bumper: next to the wheel.
Once the bumper is pushed out the way, there should be three screws that hold the housing in place. The screws are located underneath the housing.
I just installed my TYC projectors, looks great. I have one problem, the bulb on my passenger housing fell out of its socket into the housing. The housing is not the low, high or turn signal, but the parking light. The hole is too small so I can't fit my fingers into it, to make matters worst, my windshiled wiper fluid bottle is kinda in the way. Help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder »</TD></TR><TR><TD CLASS="quote">Anyone with any experience in these have any good info about them? Such as any reason not to buy them...</TD></TR></TABLE>
Out of all the aftermarket projectors I believe these are the best. They have a pretty decent cutoff with a HID kit. A lot of the 6th gen guys get these. IMO its not my taste but if you like it more power to you.
These are the bes fit aftermarket lights out there. I suggest getting them if you want brighter, safer lighting. I have HID in them, and these are better than when I had my HID in stock housing. the only bad thing about this is it doesn't come with fog lights.
i didnt have to take anytthing off to replace my headlights, they werent tyc but still andi got a 99 accord, and i also amm in MN so if you need help i can try to help
miksew
Acura TL, RL & ZDX
11
Sep 24, 2008 06:07 PM
ef_you_again
Apr 10, 2005 12:57 PM
