Lighting HID/Xenon kits, Retrofits and Associated Topics
how to check HID bulb
Old Dec 5, 2007 | 02:11 PM
vtecnique69's Avatar
Default how to check HID bulb
my friend has an 02 altima and both HIDs won't turn on. any way to check if its the bulbs or ballasts without getting electocuted ?
*disclamer* i don't know much about altimas, but the dealer wants to charge "$500 for bulb replacement" so i assume they have HIDs (3.5 liter model)
Old Dec 5, 2007 | 02:12 PM
xtrac1's Avatar
rookn00b
Default Re: how to check HID bulb (vtecnique69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecnique69 &raquo;</TD></TR><TR><TD CLASS="quote"> but the dealer wants to charge "$500 for bulb replacement" </TD></TR></TABLE>
lol
Old Dec 5, 2007 | 02:20 PM
Tizight's Avatar
Make sure you take the bulb out of the headlight and touch it with your oily fingers.
Old Dec 5, 2007 | 03:02 PM
sponge's Avatar
Default Re: (Tizight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizight &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you take the bulb out of the headlight and touch it with your oily fingers. </TD></TR></TABLE>
QFT
Old Dec 5, 2007 | 03:03 PM
i'll be sure to do that. then i'll plug it back in and watch it explode
Old Dec 5, 2007 | 03:05 PM
sponge's Avatar
Default Re: (vtecnique69)
i'll be sure to do that. then i'll plug it back in and watch it explode </TD></TR></TABLE>
That's assuming that it lights up in the first place.
Old Dec 5, 2007 | 03:11 PM
RaysBoomBoomLude's Avatar
Default Re: (sponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sponge &raquo;</TD></TR><TR><TD CLASS="quote">
That's assuming that it lights up in the first place. </TD></TR></TABLE>
LOLERCAUST
awesome, Plug the **** into another car.
I really doubt the wiring went bad or the ballasts.
Multimeter would make short work of that, fo sho!
Old Dec 5, 2007 | 03:22 PM
nek0's Avatar
OEM D2R bulbs are only $100 for pair or less on eBay
http://cgi.ebay.com/ebaymotors...ZWDVW
Both bulbs going out are less likely, they should last the lifetime of your vehicle. Does the bulb flicker at all when you turn it on? It should 'click' when you first turn on (sound of the mechanical switch). If you don't hear any click then chances are there may be other issues like the fuse & simple things.
Unless you take apart the HID ballast housings & short the capacitors you're not going to get zapped.
EDIT: I guess Altima's use D2R's not D2S's.
Old Dec 5, 2007 | 03:32 PM
Default Re: how to check HID bulb (nek0)
i'll double check tomorrow, but nothing clicks and the bulbs won't flicker. they just don't turn on. the high beams work though so thats how she's been driving lately.
i thought it was odd that both lights wouldnt turn on so i figured someone in GDD might be able to give me some insight.
where would i probe with the multimeter, the bulb harness?
Old Dec 5, 2007 | 03:44 PM
ucb's Avatar
ucb
if you hear 0 noise at all (not even buzzing from the ballasts??) then you likely blew a fuse
Old Dec 5, 2007 | 03:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nek0 &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT: I guess Altima's use D2R's not D2S's.</TD></TR></TABLE>
i saw that on a website. thx for the reminder tho!
Old Dec 6, 2007 | 12:09 AM
Default Re: (DsevenEm2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsevenEm2 &raquo;</TD></TR><TR><TD CLASS="quote">pics of said..her</TD></TR></TABLE>
have none.
sorry.
i fail deduct points at will
Old Dec 6, 2007 | 04:26 AM
devani's Avatar
bulbs turns to purple color and lose lumens....besides 02 altima is not that old to colorshift...
ballasts are not getting power somehow...check the fuses first and check the ballasts...i know that's easy to say...
I have spare ballasts just in case..so I just have to plug in
Modified by devani at 7:35 AM 12/7/2007
Old Dec 6, 2007 | 01:50 PM
Genuine Rolla's Avatar
I would definitely check the fuses first.
spotscivic
May 30, 2007 02:11 PM
AK94GSR
May 11, 2007 04:15 PM
SuicideSlide
Dec 20, 2004 03:25 PM
analbeads
Sep 10, 2004 10:22 AM
Tommy_Gunns
Oct 24, 2003 03:59 PM
