ABS LIGHT
ive searched and nothing
my problem is.. everytime i start the car, this buzzing sounds comes from the engine bay and it would go for like 10-15 seconds. then once the abs light comes on, the sound goes away.
whats wrong with it?
i got a 95 coupe ex
i got a 95 coupe ex
Find the plug that you jumper when you read CEL error codes. Same procedure, but the ABS light will flash out it's code.
Look at the top of the Integra forum, there's a sticky thread about ECU & ABS codes. Somewhere in there is the ABS codes for '94-'97 Integra. The codes & the syntax of flashing should be the same. I think only the location of the jumper wire is different.
LS1powered
Apr 27, 2006 09:13 PM
