is there a difference in a 96 DX engine harness and a 96 LS engine harness?
Old Jan 13, 2005 | 06:48 PM
1.8's Avatar
1.8
Default is there a difference in a 96 DX engine harness and a 96 LS engine harness?
anything different? any wires longer, shorter, etc??
Old Jan 13, 2005 | 06:49 PM
civictildeath's Avatar
Default Re: is there a difference in a 96 DX engine harness and a 96 LS engine harness? (1.8)
ummm vtec??
Old Jan 13, 2005 | 06:51 PM
1.8's Avatar
1.8
Default Re: is there a difference in a 96 DX engine harness and a 96 LS engine harness? (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">ummm vtec??</TD></TR></TABLE>
uhhh...did u read it?
Old Jan 13, 2005 | 06:52 PM
ummm (thinking) vtec (question to make sure)
Old Jan 13, 2005 | 06:55 PM
sohcvtec1995's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">ummm (thinking) vtec (question to make sure)</TD></TR></TABLE>
you are an idiot. dx -non vtec LS- non vtec
Old Jan 13, 2005 | 06:57 PM
Default Re: is there a difference in a 96 DX engine harness and a 96 LS engine harness? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">
you are an idiot. dx -non vtec LS- non vtec</TD></TR></TABLE>
im thinking LS teg vtec so thats why i asked
Modified by civictildeath at 12:29 AM 1/14/2005
Old Jan 13, 2005 | 06:58 PM
1.8's Avatar
1.8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">you are an idiot. dx -non vtec LS- non vtec</TD></TR></TABLE>
lol. i just wanted someone else to say it.
Old Jan 13, 2005 | 07:10 PM
saywhat's Avatar
on subject... there are a few differences between the harnesses, nothing major, I did the same swap on my 97 dx and there wasn't anything to extensive, but it still wasn't as easy as I would have liked it to be. You will have to lengthen some wires to make them fit good and not tight. You will have to switch the IACV from a three wire to a two wire connector, and the Crank Flucktuation sensor is also going from a three wire to a two wire. I am sure there is something I am forgetting but hope this helps
Old Jan 13, 2005 | 07:15 PM
1.8's Avatar
1.8
Default Re: is there a difference in a 96 DX engine harness and a 96 LS engine harness? (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat &raquo;</TD></TR><TR><TD CLASS="quote">on subject... there are a few differences between the harnesses, nothing major, I did the same swap on my 97 dx and there wasn't anything to extensive, but it still wasn't as easy as I would have liked it to be. You will have to lengthen some wires to make them fit good and not tight. You will have to switch the IACV from a three wire to a two wire connector, and the Crank Flucktuation sensor is also going from a three wire to a two wire. I am sure there is something I am forgetting but hope this helps </TD></TR></TABLE>
so the civic harness has 3 wire IACV and a 3 wire crank sensor? or the other way around.
Old Jan 13, 2005 | 07:17 PM
im thinking LS teg vtec so thats why i asked</TD></TR></TABLE>
what the hell is a ls teg? is that some jdm motor?
Revolver's Avatar
The LS Teg isnt VTEC either jackass
Old Jan 13, 2005 | 07:25 PM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">so the civic harness has 3 wire IACV and a 3 wire crank sensor? or the other way around. </TD></TR></TABLE>
Correct, the crank sensor by the oil pump, not in the dist.
Old Jan 13, 2005 | 07:26 PM
1.8's Avatar
1.8
thanks guys. i got it. like my sig?
Old Jan 13, 2005 | 07:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys. i got it. like my sig? </TD></TR></TABLE>
love it.
Old Jan 13, 2005 | 08:16 PM
skunk2finatic's Avatar
Default Re: is there a difference in a 96 DX engine harness and a 96 LS engine harness? (Revolver)
I believe another difference is the knock sensor.....There is none on a 96 civic, though there is one on LS.
Old Jan 13, 2005 | 08:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolver &raquo;</TD></TR><TR><TD CLASS="quote">The LS Teg isnt VTEC either jackass</TD></TR></TABLE>
DEAR GUN,
do i have a teg?? NO
do i have a teg engine?? NO
do i say or pretend to know about teg engines?? NO
did i ask a simple question and get burnt to hell?? YES
why?? i dont know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">dx -non vtec</TD></TR></TABLE> KNEW THAT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">LS- non vtec</TD></TR></TABLE> DID NOT KNOW THAT'S WHY I ASKED
sincerely,
Old Jan 13, 2005 | 08:31 PM
Revolver's Avatar
DEAR GUN,
why?? i dont know
KNEW THAT
sincerely,
Very simple solution to things like this......dont post if you dont know the answer! Jackass!
Old Jan 13, 2005 | 08:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolver &raquo;</TD></TR><TR><TD CLASS="quote">Very simple solution to things like this......dont post if you dont know the answer! Jackass! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">im thinking LS teg vtec so thats why i asked </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">did i ask a simple question and get burnt to hell?? YES
sincerely,</TD></TR></TABLE>
i see no answers only questions from me
Old Jan 13, 2005 | 08:44 PM
huntarrr's Avatar
wow, you didn't know a b18b was non-vtec?
GOSH /napolean
Old Jan 13, 2005 | 08:48 PM
Default Re: is there a difference in a 96 DX engine harness and a 96 LS engine harness? (vsm98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic &raquo;</TD></TR><TR><TD CLASS="quote">wow, you didn't know a b18b was non-vtec?
GOSH /napolean</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote"> do i say or pretend to know about teg engines?? NO
but everywhere i see ls vtec but dont care too much to read up on it
and no i dont know who napolean is either and really dont care to know
Old Jan 13, 2005 | 09:00 PM
and no i dont know who napolean is either and really dont care to know</TD></TR></TABLE>
Thats funny cause you are always [posting on peoples threads to search. Maybe you should try it sometime, and learn a few things.
Old Jan 13, 2005 | 09:12 PM
Revolver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">is there a difference in a 96 DX engine harness and a 96 LS engine harness? (1.8) anything different? any wires longer, shorter, etc??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">but dont care too much to read up on it</TD></TR></TABLE>
Thats funny cause you are always [posting on peoples threads to search. Maybe you should try it sometime, and learn a few things.</TD></TR></TABLE>
Good one. Just give it up or leave
Old Jan 13, 2005 | 09:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">dont care too much to read up on it</TD></TR></TABLE>
Old Jan 13, 2005 | 09:43 PM
dantastic's Avatar
wow. they're really different. the integra harness has totally different plugs going into the car harness. while the EK civic harness has all the plugs on the passenger side of the car, the integra has 3 plugs on the passenger side, one on the drivers side.
most of the sensor plugs to the motor are the same tho
Old Jan 14, 2005 | 08:54 AM
saywhat's Avatar
Default Re: (dantastic)
yeah most of the sensors are the same, there is no knock sensor. I would just cut up the integra harness and modify the civic harness like soldering on the integra plugs you need, you only have to change like 3 plugs and the rest are the same. some will need to be lengthened.
