210,000 miles 94 gsr
Old Jan 13, 2005 | 04:38 PM
doggydog's Avatar
Default 210,000 miles 94 gsr
What oil grade should I be using? Also need to replace exaustheader gasket. Is it difficult? Thanks in advance guys. (stock engine, only mods JUN cams and flywheel)
Old Jan 13, 2005 | 04:56 PM
rgaray's Avatar
Make sure both surfaces are free of old gasket material or any debris, and follow the torque sequence recommended by the manufacturer.
Old Jan 13, 2005 | 05:20 PM
Gekko's Avatar
Default Re: (rgaray)
As far as oil, maybe I'm wrong but I've been using regular Castroil 10W-30 in my B18A1 with 267,000 and it's fine.
Old Jan 13, 2005 | 05:22 PM
l2Y4N's Avatar
Default Re: 210,000 miles 94 gsr (doggydog)
header gasket is VERY easy, btw, congrats on 210, im up to 161 on my 96
Old Jan 13, 2005 | 11:37 PM
nygsr's Avatar
Default Re: 210,000 miles 94 gsr (integraTracer)
yea haha im at 224k on my motor..still runs strong!!
Old Jan 14, 2005 | 03:40 AM
s2kkid's Avatar
Default Re: 210,000 miles 94 gsr (nygsr)
mine almost saw 200k... 197,387 miles of hard abuse by previous kid owner. Should be back on the road soon!
Old Jan 14, 2005 | 04:30 AM
furious94ls's Avatar
Default Re: 210,000 miles 94 gsr (vtecluder97)
Header gasket is easy to replace. As long as that motor is in good condition (have a compression and leakdown test performed) you should stick with what the owners manual says. 5w30 is more than fine.
Why does the car have cams if it's stock otherwise? Do you plan on I/H/C/E and tuning? You will also need cam gears.
Old Jan 14, 2005 | 04:48 AM
xfrankx's Avatar
Default Re: 210,000 miles 94 gsr (furious94ls)
i got a while before 210 ( well i guess not that long haha)
Old Jan 14, 2005 | 05:05 AM
Danziver's Avatar
Default Re: 210,000 miles 94 gsr (xfrankx)
170k on my 94 and running like a champ I use 10w-30.
Old Jan 14, 2005 | 05:21 AM
94gsrsedan's Avatar
172 ON MINE NOW
Old Jan 14, 2005 | 05:26 AM
HONDA RR's Avatar
Default Re: 210,000 miles 94 gsr (Danziver)
Use the same 5w-30 mobil 1 fully synthetic.
Old Jan 14, 2005 | 07:24 AM
TeaAddict's Avatar
Default Re: 210,000 miles 94 gsr (MITSUBA)
i'm almost @ 70k...
ahahah sooo 3x to you...
Old Jan 14, 2005 | 08:15 AM
integyup's Avatar
Default Re: 210,000 miles 94 gsr (TeaAddict)
damn i thought me crossing 160k was a lot haha
Old Jan 16, 2005 | 03:32 AM
EnjoyTheRideDC2's Avatar
Default Re: 210,000 miles 94 gsr (integyup)
286,400 and counting on my DB8....tranny could use a swap, but still running pretty strong. I've used both 5w and 10w 30 oil and find 5w runs a tad better than 10w. In cold weather, I noticed with 5w oil my motor tends to start up a lot less harsh. I guess I'll have to see what its like this summer.
Old Jan 16, 2005 | 01:54 PM
MikeTV
Guest
Posts: n/a
Default Re: 210,000 miles 94 gsr (EnjoyTheRideDC2)
190,000 here.....pennzoil 5w30 all day
mdb4879
Feb 25, 2013 10:56 PM
SuciaEk420
Jan 1, 2012 03:29 PM
xgenn786
Oct 27, 2005 04:41 AM
JonnySBeee...
Jan 15, 2005 10:18 AM
KamikazeTypeR
Oct 2, 2001 09:29 AM
