Mounting 94 + integra cluster
Old Jan 13, 2005 | 04:28 PM
HatchBox's Avatar
Skoobie no more...
Default Mounting 94 + integra cluster
Can i use cloth in the back to support the cluster
I have searched but no real answers came up
Old Jan 13, 2005 | 06:21 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Mounting 94 + integra cluster (HatchBox)
Old Jan 13, 2005 | 06:55 PM
GSRCRXsi's Avatar
i cut off all the tabs on the cluster itself (since it wont fit otherwise), drilled holes into the back of the cluster, and made brackets to mount it to stock mounting points.
Old Jan 13, 2005 | 06:58 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Mounting 94 + integra cluster (GSRCRXsi)
pictures by any chance?
Old Jan 13, 2005 | 07:06 PM
Custom Rex's Avatar
just put it in, and leave it, mine just sits there perfect,
GSRCRXsi's Avatar
sorry i didnt take any the only pics i have are before it was mounted. let me see if i can find some other pics and show you where i drilled holes.
Old Jan 13, 2005 | 07:07 PM
GSRCRXsi's Avatar
Default Re: Mounting 94 + integra cluster (Custom Rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Custom Rex &raquo;</TD></TR><TR><TD CLASS="quote">just put it in, and leave it, mine just sits there perfect, </TD></TR></TABLE>
its also quite unsecure like that too. the reason i bolted it down. its annoying.
Old Jan 13, 2005 | 07:12 PM
HatchBox's Avatar
Skoobie no more...
it falls back, there is nothing holding it from the back so theres a gap between cluster and guage cover..
Old Jan 13, 2005 | 07:36 PM
GSRCRXsi's Avatar
ok sorry for the bad pics. i grabbed them from other sites
anyway this is what i did. first start by cutting off the tabs seen here :
next i drilled holes in the back of the cluster located here and here. sorry for the bad pic, but i couldnt find one the showed exactly where i drilled but there should be a small area of flat spot where a hole would not interfere with anything
then i made a bracket that looked more or less like this. dont bother asking measurements cause i didnt take any. i didnt feel like trying to take measurements in such a tight space. i just eyeballed it and adjusted it/ redid it where necessary. i just used little 1/2" thick peices or aluminum that i had lying around. scrap metal basically
and then i bolted the bracke to the back of the cluster then bolted threw the bracket into these holes on the crx:
only thing is that the cluster sits a good deal back when doing this, i just filled the gap by pulling the bracket away from the cluster with a bunch of washers. hope i helped
Old Jan 13, 2005 | 07:41 PM
HatchBox's Avatar
Skoobie no more...
so would cloth work for the time being?
i cant imagine the back for the cluster getting that hot...
Old Jan 13, 2005 | 07:43 PM
GSRCRXsi's Avatar
i guess it would work, its just not what i would do. i dont like ghettofying things . and no it shouldnt get hot at all, at least not hot enough to hurt anything
Old Jan 13, 2005 | 07:46 PM
HatchBox's Avatar
Skoobie no more...
well just time being so i can get my interior somewhat together..
BiggieBert
Jul 29, 2008 04:05 PM
daibloblanco
May 6, 2008 07:25 PM
3s0n3
Apr 19, 2007 01:08 AM
xxwhixx
16
Apr 5, 2006 08:55 AM
