backfire through the intake
Old Jan 13, 2005 | 04:20 PM
Slider89's Avatar
Default backfire through the intake
everytime i try to turn on my car it just backfires through the intake. its a 89 civic hatchback with a b16a obd-0 so any helpful answer or suggestions
Old Jan 13, 2005 | 04:34 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: backfire through the intake (Slider89)
Backfiring through the intake sounds like a timing issue or bent
or mis-adjusted intake valves..
Edit:Also check the distributor/cap and the rotor..
Old Jan 13, 2005 | 09:38 PM
fed's Avatar
fed
its your timeing when i had my d16 it did the same thing because i was off a tooth
Old Jan 18, 2005 | 01:33 PM
Slider89's Avatar
thxs guys ill look at it.
Old Jan 18, 2005 | 01:42 PM
hahagasdcrx's Avatar
usually backfires through the intake means your timing is @ 180 degrees off. Check spark plug wire to see if you have them right.
Old Jan 18, 2005 | 02:58 PM
Mordeki's Avatar
Abusing my rights one day at a time.
Default Re: backfire through the intake (hahagasdcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx &raquo;</TD></TR><TR><TD CLASS="quote">usually backfires through the intake means your timing is @ 180 degrees off. </TD></TR></TABLE>
Old Jan 30, 2005 | 08:15 PM
EG6R's Avatar
What does backfire through the intake mean?
Old Jan 31, 2005 | 06:38 AM
Chronicsinners's Avatar
Default Re: backfire through the intake (Mordeki)
180 degrees off ---
Old Jan 31, 2005 | 06:46 AM
EP3_05's Avatar
Default Re: backfire through the intake (EG6R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R &raquo;</TD></TR><TR><TD CLASS="quote">What does backfire through the intake mean? </TD></TR></TABLE>
Backfiring through the intake means the spark plugs are lighting the air fuel mixture while the intake valves are open. This means the timing is off.
Old Jan 31, 2005 | 05:47 PM
EG6R's Avatar
Default Re: backfire through the intake (91civic)
How is this detected? Does the car still start?
Old Feb 1, 2005 | 07:17 PM
efhatchster's Avatar
of course it does it's just gonna sound a lil bite off
Old Feb 1, 2005 | 07:22 PM
Widebody1's Avatar
no it wont start, it thinks the intake is the exhaust and the exhaust is the intake. Its def. your wire order....
Old Feb 1, 2005 | 08:18 PM
iNetForce's Avatar
Default Re: (Widebody1)
ive been there, done that
check your distributor cap and rotor. ( A bad distributor cap could cause your car to back fire, even to smoke out of the intake )
I suggest you do a tune up.
Old Feb 2, 2005 | 12:03 AM
efektionz's Avatar
has it benn raining? did you get the distirb. cap wet? if it did get wet. then thats the cause... it happend to my hatch also. let it dry out or u can open it n dry it. and it should work right up. if not then ur cap must be gone
Old Feb 2, 2005 | 04:08 AM
mellon's Avatar
Default Re: (efektionz)
Do a compression test. I had a couple bent valves when my car was doing that...
mkcivic
Jun 17, 2007 05:26 PM
JLefevers
May 19, 2006 04:15 AM
juniestyle
Apr 24, 2006 09:53 PM
EGRhatch
Aug 5, 2003 11:00 PM
senpai
Jul 24, 2003 02:13 PM
