o2 sensor for 95 integra gsr
Old Jan 13, 2005 | 02:41 PM
jdmxxdc2's Avatar
Default o2 sensor for 95 integra gsr
o2 sensor for 95 integra gsr - is there a way to rewire o2 sensor to make it longer.... reason is i bought a ls cat and the o2 sensor is on different side and i need to make the wire longer... plz help!
Old Jan 13, 2005 | 02:58 PM
shhh151's Avatar
Default Re: o2 sensor for 95 integra gsr (jdmxxdc2)
umm i think the o2 sensor is on the header not the cat. itself
Old Jan 13, 2005 | 03:02 PM
shhh151's Avatar
OBD1 = 1 o2 --> before the cat.
OBD2 = 2 o2 --> one before the cat and one after the cat.
Old Jan 13, 2005 | 03:09 PM
sabotage7's Avatar
my o2 sensor on my 94 gsr is on the cat right by the inlet.
jdmxxdc2's Avatar
Default Re: o2 sensor for 95 integra gsr (GSR515)
yea i got obd1... o2 sensor on the cat... is there a way i can extension to make the wires longer...
Old Jan 13, 2005 | 03:26 PM
shhh151's Avatar
hmm thats strange when i got my header, cat, exhaust, i didn't see a hole for the o2 on the cat but i did see a hole in the header.
im just going by what i saw, i may be wrong.......?
Old Jan 13, 2005 | 03:27 PM
sabotage7's Avatar
you should be able to just add wire....youd want to solder and heatshrink though to ensure a good clean connection....i know when you purchase the universal o2 sensor at the parts store, it comes w/heatshrink and i think some connectors.
Old Jan 13, 2005 | 03:48 PM
jdmxxdc2's Avatar
Default Re: o2 sensor for 95 integra gsr (sabotage7)
would i need heatshrink wires or tape?
Old Jan 13, 2005 | 04:02 PM
sabotage7's Avatar
just get some regular wire thats the same guage as whats on there now and solder it to the existing wires to lengthen it, put some of that black heat shrink tape over each solder connection and then wrap it all up together with electrical tape.
Old Jan 13, 2005 | 08:17 PM
jdmxxdc2's Avatar
sweet i will do just that... thanks for everyones inputs
DOHCter VTEC
Dec 29, 2007 02:23 PM
j0hnniz
Aug 16, 2006 07:02 PM
WIb16crxWI
May 18, 2006 12:42 PM
dylokjai
Nov 23, 2004 11:11 AM
964dgsr
Sep 25, 2003 07:53 AM
