LX to EX brake conversion
Old Jan 13, 2005 | 01:41 PM
remo's Avatar
Default LX to EX brake conversion
Hi all, I have a 99 LX and i want to replace the front discs with EX ones. Will this cause anyproblems? I read that if you only upgrade the front it creates an imbalance when you brake. I dont want to do the disc conversion on the rear drums for now. Is there anything I need to think of before doing the swap?
Old Jan 13, 2005 | 01:48 PM
poison's Avatar
Default Re: LX to EX brake conversion (remo)
You'll just need the calipers and the brake rotors. Then bolt on and bleed the brakes.
No ill effects at all.
Old Jan 13, 2005 | 03:13 PM
EL Vap133's Avatar
Default Re: LX to EX brake conversion (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">You'll just need the calipers and the brake rotors. Then bolt on and bleed the brakes.
No ill effects at all.</TD></TR></TABLE>
You forgot the brake pads too...
Old Jan 13, 2005 | 03:45 PM
poison's Avatar
Default Re: LX to EX brake conversion (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
You forgot the brake pads too... </TD></TR></TABLE>
bleh
civicguru
Honda Civic (2006 - 2015)
Nov 6, 2008 04:53 AM
Basically
Sep 22, 2005 08:11 AM
95LSDOHC
Dec 2, 2004 11:15 AM
Tutin77
Sep 18, 2004 09:42 AM
brian2903
Dec 16, 2003 07:04 AM
