Surging idle still!! Please help!
Old Jan 13, 2005 | 01:03 PM
Tronix102's Avatar
Default Surging idle still!! Please help!
I have had the dreaded surging idle for a long time. I read numorous threads on how to fix it and nothing seems to work. I narrowed it down to the TPS. When the harness is pluged into the TPS and the engine warms up...normal temp. if u give it some gas to say 3000rpm and take your foot off fast the idle drops very fast almost to stalling and then it surges up and down between 2k and 1k then u give it some gas again and it stops. I have replaced the TPS with another one that I purchased...I checked the voltage and I set it at .45 Now of course if I unplug the TPS from the harness it doesnt surge, it doesnt drop in idle fast. So what the hell!! Is the voltage set wrong? Is there something else I can do? Please help because drive with it unpluged and the check engine light is driving me nuts.
Old Jan 13, 2005 | 08:31 PM
Tronix102's Avatar
Default Re: Surging idle still!! Please help! (Tronix102)
anyone?
Old Jan 13, 2005 | 11:06 PM
Hawkze_2.3's Avatar
I'd say try adjusting it a little each way.....not exactly to spec, but just try different positions.
Old Jan 13, 2005 | 11:35 PM
Tronix102's Avatar
Default Re: Surging idle still!! Please help! (Hawkze_2.3)
I'll try but i'm about to throw my car out. LOL
Old Jan 14, 2005 | 07:57 AM
Under_Pressure's Avatar
Did you check you iacv? Thats a cause of that somethimes also a vac leak somewhere. One last thing the screw on top of th TB have you tried ajusting?
Old Jan 14, 2005 | 08:09 AM
PrettyLude's Avatar
see if your tps needs to be calibrated, check ur iacv, vacuum leaks
4tika4
Sep 25, 2009 09:28 PM
Thorgs
Apr 20, 2008 09:31 AM
whitediamond642
Apr 10, 2007 04:37 AM
SWC
Apr 5, 2006 05:37 PM
HybriDNA
Feb 10, 2004 04:09 PM
