For the D15B tuners
Old Jan 13, 2005 | 11:33 AM
wagonis's Avatar
Default For the D15B tuners
Got a D15B7 (weak ***), with an AEM CAI and some exhaust, but dunno which.
I've been searching the forums, and put together a combo, but need opinions about it.
Skunk2 intake (for D16AZ though)
DC 4-2-1 Header
AEM High volume fule rail
Adding those to what I already have... should I bother?
Old Jan 13, 2005 | 11:37 AM
busta's Avatar
Default Re: For the D15B tuners (wagonis)
honestly i wouldn't waste time with that...just go turbo!
Old Jan 13, 2005 | 11:46 AM
wagonis's Avatar
Default Re: For the D15B tuners (lilobusta)
Are you serious? Why go turbo right off the bat?
Old Jan 13, 2005 | 11:48 AM
snatch's Avatar
I certainly wouldn't bother with the fuel rail. It's just not worth it. The intake, doubtfully, I think I'd swap a Z6 intkae manifold over if I were you, and also get a tranny from either a 92-95 EX/Si, or from 96-00 EX. Both of those will have much shorter gearing and make the car accelerate faster. Those 2 things alone will help tremendously. Then see how you like it. The header isn't a bad idea though.
Old Jan 13, 2005 | 11:55 AM
busta's Avatar
Default Re: For the D15B tuners (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wagonis &raquo;</TD></TR><TR><TD CLASS="quote">Are you serious? Why go turbo right off the bat?
um....just my .02...with the amount of money you spend on all that stuff you could
probably put together a kit and make an extra 45-50 horse...
Old Jan 13, 2005 | 11:59 AM
sockvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">I certainly wouldn't bother with the fuel rail. It's just not worth it. The intake, doubtfully, I think I'd swap a Z6 intkae manifold over if I were you, and also get a tranny from either a 92-95 EX/Si, or from 96-00 EX. Both of those will have much shorter gearing and make the car accelerate faster. Those 2 things alone will help tremendously. Then see how you like it. The header isn't a bad idea though.</TD></TR></TABLE>
the y8 intake manifold would be better...that is if it would fit that d15
Old Jan 13, 2005 | 12:05 PM
wagonis's Avatar
Default Re: For the D15B tuners (zoomzoom92)
What's your opinion on this engine in general? It's currently got 124K and change, and feels like it runs strong, and i'd hate to swap engines while this one is still good.
Old Jan 13, 2005 | 12:08 PM
POE's Avatar
POE
dude, u would be waisting money on puting a fuel rail on there, no need, if u were u i would do a mini me swap, and then put a ex tranny, then boost it, or tune it, with a vafc or uberdata, if u boost it after the mini me, use arp head bolts or your head will lift from the block.
Old Jan 13, 2005 | 12:18 PM
DJ_SaNdOz's Avatar
Default Re: For the D15B tuners (Vtecin94dx)
you could also pick up a stock D16A6 cam for cheap and that will certainly give the car some more pep.....
Old Jan 13, 2005 | 12:19 PM
wagonis's Avatar
I guess I'm just trying to establish a goal with this car, so I don't start doing and/or planning without a clue. I'd like for my car to be quick, but I'm not going racing any time soon, if never. At most, I may take this thing to the 1/8 mile to see what I got (no 1/4 close by). Just want to be as realistic as possible.
Old Jan 13, 2005 | 12:20 PM
wagonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">you could also pick up a stock D16A6 cam for cheap and that will certainly give the car some more pep.....</TD></TR></TABLE>
That cam would work with my D15B7? So there are quite a few parts from the D16 that will bolt in nicely I assume? Cam, intake, what else?
Old Jan 13, 2005 | 12:25 PM
POE's Avatar
POE
yeah if u want a few hp get a d16a6 cam from the crx si's they will bolt in fine, but im not sure about other d16 cams
Old Jan 13, 2005 | 12:28 PM
hype r 555's Avatar
i agree , the fuel rail , probablty isn't the best to tart , the mani and header , would be a plus .... and intake always helps ..... i would just jump into a turbo either , that will end up costing alot more than it's worth ....
Old Jan 13, 2005 | 12:29 PM
POE's Avatar
POE
mini me it for like 300 bucks and get like 20 hp
Old Jan 13, 2005 | 12:31 PM
egizzle8
Guest
Posts: n/a
Default Re: (Vtecin94dx)
I'm putting a a6 head on my cx block and swapping it in tonight. I should be pretty zippy and pretty lively with a act prolite flywheel and lighten crank pulley(yeah yeah save it with the pulley) and 4-1 DC header in my hatch. Just need to get a chip for the ecu now to get the most outta it. Only thing I heard is just put a b7 cam gear on it and you'll be set with timing.
DJ_SaNdOz's Avatar
IIRC the D16A6 & the D15B7 share the same head, the difference being the cam.
I suggest that you spend a few hours reading the archived content, Honda made lots of parts interchangable between their various products. There is quite a bit of d series tech here. Good luck.
Old Jan 13, 2005 | 01:58 PM
RagingAngel's Avatar
Default Re: For the D15B tuners (DJ_SaNdOz)
Why not Z6 intake manifold?
B18B throttle body
Z6 tranny
add your DC header.... plus the A6 cam?
Majority of the "gains" will come from the better gearing..... At sea level my friend's rebuilt B7 (all stock internals) minus the throttle body made 107whp
Old Jan 13, 2005 | 02:54 PM
wagonis's Avatar
Default Re: For the D15B tuners (RagingAngel)
OUCH!!! MY BRAIN HURTS!!! Okay, so you guys are saying change the cam, the cam gears, the intake, the tranny... all from interchangable engines, slap the header as well, and I got me some nice ponies?
Okay, I need to read up on the interhcangability of these parts, and the pros and cons of each.
Old Jan 13, 2005 | 02:57 PM
jerbear!'s Avatar
d-series.org has plenty of information. a crx si cam (d16a6) cam would help and it doesnt cost that much. depending on what yr a6 cam u get u may need a cam gear.
Old Jan 13, 2005 | 03:54 PM
NeverEverSatisfied's Avatar
Call up Paul Walker and have him hook ya' up with 1,000 shot of NNNAAWWWWSSSS.
Old Jan 13, 2005 | 05:42 PM
POE's Avatar
POE
You want your car to be quick well how quick is quick to you is it TURBO quick or just Mustang QUICK or maby even 2 fast 2 furous quick? hummmmm..........
I vote going DOHC yep that's were it is at
Old Jan 13, 2005 | 05:57 PM
wagonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx &raquo;</TD></TR><TR><TD CLASS="quote">You want your car to be quick well how quick is quick to you is it TURBO quick or just Mustang QUICK or maby even 2 fast 2 furous quick? hummmmm..........
I vote going DOHC yep that's were it is at </TD></TR></TABLE>
I guess i'd like to match up with a Stang GT, that would be enough for me. Taking it would be nice, but i'd like to at least match it.
Now, the DOHC, is that the mini-me swap? I was told that I should go for an LS block, with a vtec top half, but I'm not looking to swap the whole engine.
Old Jan 13, 2005 | 06:02 PM
MulletManRockStar's Avatar
crane cam for d16a6 would work. Intake from JG or Skunk 2 will add some. Bigger injectors if you get a bigger cam. A si/ex trans will help having a better final drive. The real question is it worth it? Not to me. Id say get a b series then turbo that. A sohc turbo will be fast but in stock form is not as strong as a b series.
Old Jan 13, 2005 | 06:07 PM
ABK's Avatar
ABK
Default Re: (wagonis)
best thing for you to do is, to get a z6 or y8 head. y8 IM, maybe a header, p28 ecu. maybe a B series 60mm TB
I would say good for like maybe 110 at the wheels
Want more N/A power get a zex cam they seem to be pretty cheap and good
Old Jan 14, 2005 | 10:22 AM
POE's Avatar
POE
that was a dude, i work with who drives a 99 SI, he loves the b16a2
sinister357
Aug 26, 2007 04:28 AM
jaywoodz
Jul 27, 2007 07:26 PM
DeDonDeRosa
Honda Civic (2006 - 2015)
Apr 27, 2006 09:37 PM
Boosteddc2gsr
Jan 13, 2004 10:30 AM
outlaw0191
Jan 9, 2004 10:01 PM
