B16A CRX Swap Smog HELP!
Ok i have a 91 CRX B16A Swap it have 2 o2 sensors on the exhaust manifold. There for the motor is a OBD0. Now from what i have been told that the best this to do is find a Del Sol 95 ECU run that ECU and Plug the O2 sensor thats not being used. Then i will be able to pass smog. ( Problem ) Del sol comp is hard to find!!
Is there any other way to do this with out re-wireing it. ? Maybe a Cheeper way. ?
Thanks
Is there any other way to do this with out re-wireing it. ? Maybe a Cheeper way. ? Thanks
You won't be able to run the 95 ecu in your crx without converting to OBD1. You will need:
OBD1 Distributor
4 wire heated O2 sensor
OBD0-OBD1 conversion harness
OBD1 Distributor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hotori Hanso »</TD></TR><TR><TD CLASS="quote">and a purple nipple clamp
hahahahaha... That was hilarious.
</TD></TR></TABLE>hahahahaha... That was hilarious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson »</TD></TR><TR><TD CLASS="quote">you could pay a little extra for your smog if you know what I'm talking about...
thats what i did.
::feels dirty::
o well. i know my car runs clean, just a little over.
</TD></TR></TABLE>thats what i did.
::feels dirty::
