EG SWAP Q: Engine Mounts?
Old Jan 13, 2005 | 10:44 AM
Jwbetley's Avatar
Default EG SWAP Q: Engine Mounts?
95 civic coupe, B18b1 Ls motor + GSR trans.
What mounts am I going to need? Which stock D-series mount, if any, can I reuse?
I am plannig on just keeping the stock mounts and installing silicone inerts. Any opinions on the urethane inserts?
Old Jan 13, 2005 | 11:38 AM
WiLLMaTiX's Avatar
Default Re: EG SWAP Q: Engine Mounts? (Jwbetley)
Go to Hasport.com and get all new mounts. There not all that expensive, so before you completely ruin everything get new ones. NEVER use old stuff when swapping unless you completely understand what your doing and what purpose everything has. Urethane inserts are good if you already have stock mounts with a stock motor in a stock car, they help. But the extra money you spend will help alot. With new Hasport mounts you will have incredible results, virtually no wheel hop and great response.
lvsdan
25
May 1, 2014 07:51 PM
Top-Fuel
Mar 23, 2006 06:45 PM
CA6VTEC
Oct 18, 2005 09:33 PM
the.hamburglar
May 31, 2005 07:05 AM
b20vtecv8killer
Aug 20, 2004 09:05 PM
