Intercooler and Fog Lights?
I have a 99 Civic Si and was wanting to know if I can install factory fogs with my Precision AS1025 intercooler without ANY fabrication. Honda will be doing this so I dont want any problems for them.
its been covered many times before. But if you want to have all your turbo stuff installed and then take the car to honda to get the fogs, they will probably have problems.
i have a mission for you. Try searching cause i already did and found nothing. thanks for the help though!
I dont want to install the fogs then not be able to install the IC. maybe ill just deal without the fogs.
If you're using pre-bent intercooler piping it's about a 90% no they won't work. Most of them place the endtanks/piping right at the "vent" part of the bumper and that is where the bulk of the fact. foglight runs. Mine works b/c we made all my intercooler piping and it runs below the foglight housing and behind the bracket. HTH.
https://honda-tech.com/zerothread?id=743762
https://honda-tech.com/zerothread?id=188781
Modified by RacerXI at 3:59 PM 1/13/2005
good luck dude i have a 99 si and there is no possible way mine will fit with my peakboost kit so i just put the gray pieces (bezels ) on and i think it looks good shows my ic piping since i already had holes in my front bumper
I don't know which model that is, but check out TwoK4drSi's pics in this thread:
https://honda-tech.com/zerothread?id=737686&page=3
He just turned it upside down.
I don't know about the Precision intercooler, but my oem fogs fit fine with my DRAG intercooler. Just had to cut off the bottom part of the bracket. I don't have pics though. Hope you have a hookup at the dealer, they always charge huge $$$ for labor.
I paid about $130 for my fog lights and installed them myself. You can do it. You'll need a chiropractic adjustment after working by the fuse box. They might end up charging you more since the fog light bracket needs to be cut.
BoostnEK6206
14
Feb 21, 2008 08:46 PM
himhimself
Jul 27, 2007 03:58 PM
