difference between k20a heads.
Old Jan 13, 2005 | 10:01 AM
h22Sicoupe's Avatar
Default difference between k20a heads.
wat is the difference between the k20a type s head and the head off of a regular rsx? i know the intake manifold is differen't and the cams, and maybe a little head work but other than that is it the same thing like the b16 and the b18c?
Old Jan 13, 2005 | 12:55 PM
thabends's Avatar
* B A N N E D *
regular rsx-s? or base rsx?
Old Jan 13, 2005 | 01:14 PM
k20whitevic's Avatar
Default Re: (thabends)
^^^ What he said.
Old Jan 14, 2005 | 01:53 AM
krystar's Avatar
well let's get some designations straight here
K20A = JDM Integra Type R
K20A2 = USDM RSX Type S
K20A3 = USDM RSX base and USDM EP3 Civic Si
that means there is no K20A type S
Old Jan 14, 2005 | 04:00 AM
Targa250R's Avatar
be professional
Default Re: difference between k20a heads. (h22Sicoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22Sicoupe &raquo;</TD></TR><TR><TD CLASS="quote">wat is the difference between the k20a type s head and the head off of a regular rsx? i know the intake manifold is differen't and the cams, and maybe a little head work but other than that is it the same thing like the b16 and the b18c? </TD></TR></TABLE>
http://www.superhonda.com/foru...05867
Old Jan 14, 2005 | 08:53 AM
Pesh's Avatar
Default Re: difference between k20a heads. (Targa250R)
That link is really informative, and the pictures showing the cam lobes are priceless. Thanks for the link.
whiteDCfiver's Avatar
^^ how does that link answer his question about heads? All it talks about is vtec.
Old Jan 14, 2005 | 03:48 PM
krystar's Avatar
well the diff between a k20a2 head and a k20a3 is the VTEC mechanism
Old Jan 15, 2005 | 10:45 AM
Default Re: (krystar)
^^ ah gotcha, thanks I thought the head is what determined the compression ratio. Or do both the vtec mechanism and compression relate to head?
Old Jan 15, 2005 | 10:54 AM
Lucid Moments's Avatar
Default Re: (whiteDCfiver)
The piston is going to be the primary factor in determing compression ratio. The connecting rods and crankshaft will affect it as well. The head might make a minor difference, but very very small.
Old Jan 15, 2005 | 02:11 PM
DC5ITR329's Avatar
Default Re: (LucidMoments)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LucidMoments &raquo;</TD></TR><TR><TD CLASS="quote">The piston is going to be the primary factor in determing compression ratio. The connecting rods and crankshaft will affect it as well. The head might make a minor difference, but very very small.</TD></TR></TABLE>
Old Jan 15, 2005 | 03:50 PM
Default Re: (aznbo1626)
Sweet thanks guys, Im glad i just learned this
powerfulperformance
May 24, 2009 07:14 PM
KW2000
Mar 1, 2003 01:05 PM
Senses Fail y0!
Jun 15, 2001 11:34 AM
