Swapping my h23 for a JDM H22....which chipped ecu??
Old Jan 13, 2005 | 09:36 AM
Monkeyballs's Avatar
Default Swapping my h23 for a JDM H22....which chipped ecu??
long story short...im swapping a jdm h22 into my 92 si, and before it goes in, its getting a 3 angle valve job, the head shaved and cam gears installed, now with all that being said...im looking into ecus and im looking into Skunk 2, Mugen or Jun chipped ecus. I talked to one guy who said he used a skunk 2 daily driving, but when he goes racing he uses the jun one....
i was just wondering if there any pros or cons to either one, or if youve heard anything on it for any input, thanks
-steve
Old Jan 13, 2005 | 09:42 AM
98TypeSH's Avatar
Default Re: Swapping my h23 for a JDM H22....which chipped ecu?? (twopoint5lude)
chipped ECU's are horrible. Sure some of those chips work for the exact cars and setup they had when they wrote the file, but each car and its history is different. i would suggest staying away from these little chips and go for a piggy back or full stand alone. try hondata or uberdata. Or hell, just get a VAFC because you havent really modified anything cept a valvejob and cam gears. I can almost promise you with your stock motor and a jun chip you will blow your motor.
Old Jan 13, 2005 | 09:52 AM
Default Re: Swapping my h23 for a JDM H22....which chipped ecu?? (98TypeSH)
really? so you think i'd be better off with just a stock usdm p13 ecu, and getting a vafc to tune it?
Old Jan 13, 2005 | 09:54 AM
hOndafienD 04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twopoint5lude &raquo;</TD></TR><TR><TD CLASS="quote">really? so you think i'd be better off with just a stock usdm p13 ecu, and getting a vafc to tune it?</TD></TR></TABLE>
chipped ecu's are a waist of gas...
Old Jan 13, 2005 | 10:31 AM
Default Re: Swapping my h23 for a JDM H22....which chipped ecu?? (hOndafienD 04)
cool, thanks for the info.....
if any more opinions, please share...
Old Jan 13, 2005 | 10:36 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twopoint5lude &raquo;</TD></TR><TR><TD CLASS="quote">if any more opinions, please share...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">chipped ECU's are horrible. Sure some of those chips work for the exact cars and setup they had when they wrote the file, but each car and its history is different. i would suggest staying away from these little chips and go for a piggy back or full stand alone. try hondata or uberdata. Or hell, just get a VAFC because you havent really modified anything cept a valvejob and cam gears.</TD></TR></TABLE>
That's about the best opinion you're gonna get
Old Jan 13, 2005 | 10:41 AM
Shakes's Avatar
space cadet
Default Re: Swapping my h23 for a JDM H22....which chipped ecu?? (SKDRCR)
Steve if i find out you are running just a chipped ECU ill fly back and kill you.
get a vafc at least. but i would suggest a Hondata. a P100 should be about the same price as the VAFC and i think shad prefers hondata (if you're having him tune it).
Old Jan 13, 2005 | 10:42 AM
i know, thats what im thinking....i guess im just waiting for someone to chime in and say they've had no problem w/their chipped ecu, but i mean i have a feeling ima just go with a stock one and tune/run it with a vafc......
Old Jan 13, 2005 | 03:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twopoint5lude &raquo;</TD></TR><TR><TD CLASS="quote">i have a feeling ima just go with a stock one and tune/run it with a vafc......</TD></TR></TABLE>
Old Jan 13, 2005 | 04:39 PM
v4lu3s's Avatar
RTFM
yeah stock ecu since your engine is gonna be stock. afterall a 3 angle valve job is stock, and slightly higher compression from head shaving wotn gain that much anyway.
Old Jan 13, 2005 | 05:34 PM
satan_srv's Avatar
Default Re: (v4lu3s)
get a real ecu.
P13 OBDI
or go do it for real and get
P28 + Hondata
don't spend money on a garbage ecu.
Old Jan 13, 2005 | 07:52 PM
JDMSloLude's Avatar
Default Re: (satan_srv)
I agree with Satan. My advice after experiencing a million problems with my swap is to go with the P13 initially. If everything is running fine then look to the P28 and run Hondata. But as everyone will say...a chipped ECU is not tuned to your car....which means problems.
Old Jan 13, 2005 | 08:16 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
P28 + Hondata
Uberdata is just as real.
Old Jan 13, 2005 | 08:28 PM
satan_srv's Avatar
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
Uberdata is just as real. </TD></TR></TABLE>
whatever, same thing...fuel management system
I could have said AEM EMS...MOTEC and a thousand others too.
Old Jan 14, 2005 | 12:20 PM
thanks everyone, i found me a stock p13 m/t ecu....thanks everyone for the input...
and doug, dont worry about flying home, unless you bring some more jungle juice with ya
grumpys93
Mar 6, 2018 07:51 AM
InvaderTrax
Apr 29, 2006 09:19 PM
ludesleep
Apr 9, 2003 04:42 PM
hybridEj6
Feb 18, 2003 06:02 AM
hooptie157
Jun 3, 2002 08:58 PM
