cf cowl style hoods? I need something for itb's to breathe.....
Old Jan 13, 2005 | 09:00 AM
Black R's Avatar
25 Year Member
Default cf cowl style hoods? I need something for itb's to breathe.....
b-series + itb's.....
So what hood is good without being too ricey?
I can cut up a cf or oem hood if necessary.
But I'd really prefer a bolt-on solution that isn't too ricey or obnoxious.....
anyone got a link/ pics?
Old Jan 13, 2005 | 01:50 PM
alecjoesph's Avatar
Default Re: cf cowl style hoods? I need something for itb's to breathe..... (Black R)
just add some skateboard doh dohs (truck bushings) in between the hinge and the hood it will prop the hood up in the back.
Old Jan 13, 2005 | 03:59 PM
Black R's Avatar
25 Year Member
Default Re: cf cowl style hoods? I need something for itb's to breathe..... (alecjoesph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alecjoesph &raquo;</TD></TR><TR><TD CLASS="quote">just add some skateboard doh dohs (truck bushings) in between the hinge and the hood it will prop the hood up in the back. </TD></TR></TABLE>
I've already shimmed the hood upwards. I want something to suck fresh air from the low pressure area in front of the windshield and push it towards the firewall/ itb/ IM area.....
Old Jan 13, 2005 | 04:35 PM
GroundZer0 336's Avatar
gude makes a cowl hood. i think they make them in cf too. http://www.gude.com
Old Jan 13, 2005 | 07:40 PM
apexinghonda's Avatar
Default Re: cf cowl style hoods? I need something for itb's to breathe..... (GroundZer0 336)
That hood looks nonfunctional (no offense). But Black R you did say a "cowl hood" though. With a B series you want clearance of the engine with the hood. The other thing you should want is a hood vent of some type not too far behind the radiator to vent out hot air which has passed through the radiator. Having been a supra owner and under the hood temp management being a big issue with modded supras several hoods along the styles I have seen on those cars would be nice. Although I have a full fluidyne radiator and an electric water pump so the temps in my car never get high.
Barry H.
Old Jan 13, 2005 | 07:53 PM
Black R's Avatar
25 Year Member
Default Re: cf cowl style hoods? I need something for itb's to breathe..... (apexinghonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apexinghonda &raquo;</TD></TR><TR><TD CLASS="quote">The other thing you should want is a hood vent of some type not too far behind the radiator to vent out hot air which has passed through the radiator. </TD></TR></TABLE>
Yes of course. But I also want a way for fresh cool air to make it's way to the intake manifold/ firewall area where the itb's reside.
A vent in the front to let heat out of the radiator =
A vent in the rear to let cool air get on those itb's =
Old Jan 13, 2005 | 07:58 PM
Black R's Avatar
25 Year Member
weird looking... i wonder if they're functional:
http://www.gude.com/Images/hoods/bhood4.jpg
http://www.gude.com/Images/hoods/bhood7.jpg
http://www.gude.com/Images/hoods/bhood9.jpg
Old Jan 13, 2005 | 09:06 PM
Default Re: (Black R)
well i really doubt it would be on the gude race car if it wasnt functional. i mean air comes in at the front, and is cowled. only other thing i would say is make one yourself.
Old Jan 13, 2005 | 09:15 PM
91civicEX's Avatar
Default Re: (GroundZer0 336)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GroundZer0 336 &raquo;</TD></TR><TR><TD CLASS="quote">well i really doubt it would be on the gude race car if it wasnt functional.</TD></TR></TABLE>
now i dont know if the hood is functional or not but is the rest of the body kit "functional"? they could just be promoting the hood. but back the the original question, im sure if its not functional you could make it functional fairly easy.
Old Jan 13, 2005 | 09:39 PM
87b16crx's Avatar
what i want to do to mine if i get ITB's is get the jdm hood and buy an STI CF hood scoop and mount it on the hood. migh tlook like rice but would be functional and different.
Old Jan 26, 2005 | 10:44 PM
doublethink's Avatar
Default Re: (87b16crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87b16crx &raquo;</TD></TR><TR><TD CLASS="quote">what i want to do to mine if i get ITB's is get the jdm hood and buy an STI CF hood scoop and mount it on the hood. migh tlook like rice but would be functional and different.</TD></TR></TABLE>
thats true, a low profile bolt on hood scoop, lazer cut a hole underneath, paint it all to match the car, it could work.
http://search.ebay.com/crx-hoo...earch
theres one for 12 bucks!
as far as channeling that air once you scoop it, thats going to have to custom.
one thing i will say, 99+ celicas have this plastic **** that moves the air from the scoop on those cars, could try modifing that stuff.
most likley youll end up making that last part tho.
what i want to know is can you run ITBs on a k20 in a crx with a hood on it, and also how do you keep water out of them if its a daily driver?
x3kevin
Feb 17, 2008 10:39 PM
OoHiTzToMMy
29
Dec 11, 2005 03:43 PM
andyboy
Nov 4, 2004 05:34 PM
cdntegintx
Jun 7, 2004 06:30 AM
HATCHingMN
Apr 28, 2004 07:34 PM
