quick question about cel and o2 sensor
Old Jan 13, 2005 | 07:46 AM
dropd4door's Avatar
Default quick question about cel and o2 sensor
ok its a 95civic witha swap will a cel for o2 sensor stop vtec from engaging? need a quick reply thanks guys
Old Jan 13, 2005 | 07:58 AM
hondaguyef's Avatar
Default Re: quick question about cel and o2 sensor (dropd4door)
No it should not.
Old Jan 13, 2005 | 08:06 AM
dropd4door's Avatar
i jus was reading some topics and some say it will work and some say it wont,,,, surposely in obd-1 vtec will work with no o2 sensor, but in obd2 it wont work,.. anyone 100% sure with obd1?
Old Jan 13, 2005 | 08:13 AM
LSracing94's Avatar
Default Re: (dropd4door)
your vtec will NOT engage with a CEL for an o2 sensor..trust me i had the same problem..change it asap because it also messes up the amount of of fuel and **** going through your engine and your car will start to run really bad.
Old Jan 13, 2005 | 08:29 AM
dropd4door's Avatar
o yeah i already noticed that i am gettin like 16 mpg lol its jus as bad as my 99 ford crown vic
Old Jan 13, 2005 | 12:20 PM
LSracing94's Avatar
lol yea dude, that is the exact problem i had..go pick up an o2 sensor at honda and you'll be good to go.
Old Jan 13, 2005 | 02:14 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropd4door &raquo;</TD></TR><TR><TD CLASS="quote">i jus was reading some topics and some say it will work and some say it wont,,,, surposely in obd-1 vtec will work with no o2 sensor, but in obd2 it wont work,.. anyone 100% sure with obd1?</TD></TR></TABLE>
Yes it will. I just went out and did the test right now(unplugged o2 and did a run). It still engages
Phil
Old Jan 13, 2005 | 04:12 PM
NeverEverSatisfied's Avatar
GOT FORD??? = GOT Fucked Over Really Bad....
Old Jan 13, 2005 | 06:00 PM
dropd4door's Avatar
Default Re: quick question about cel and o2 sensor (NeverEverSatisfied)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeverEverSatisfied &raquo;</TD></TR><TR><TD CLASS="quote">GOT FORD??? = GOT Fucked Over Really Bad.... </TD></TR></TABLE> what
Old Jan 13, 2005 | 07:57 PM
LSracing94's Avatar
i had obd1 on a sirII b16..can u please just listen to me..hondaguyef stop giving bad advice if you dont know what youre talking about..im not an idiot i have gone through and fixed this EXACT problem...when you have an engine swap..(which you do)..a bad primary o2 sensor will prevent your vtec from engaging..thank you..everyone else whothinks i'm wrong is an idiot..good night
Old Jan 13, 2005 | 09:04 PM
PuiPui's Avatar
Default Re: quick question about cel and o2 sensor (LSracing94)
really because i just swapped a 92si with a b16a2 and my check engine light is on with the primary o2 code, the setup is using chipped p28 so its obd1, and my vtec engages just fine, theres just no pull after 7000 heh
i must be an idiot. i don't even know when my own vtec engages... YO!
Old Jan 13, 2005 | 09:14 PM
GSlowR's Avatar
wouldn't that be GOT FORB??
Old Jan 14, 2005 | 07:14 AM
LSracing94's Avatar
Default Re: quick question about cel and o2 sensor (GSlowR)
welll idk what to tell you..i am trying to fix this kids problem and you guys gotta be cocky and tell him that isnt the problem when i really know that it is.
ToTriggerHappy
Jan 28, 2011 04:18 PM
StreetwizeRacin2
Apr 6, 2004 03:16 PM
Vtecfool
Mar 28, 2004 12:38 PM
LS stretch
Mar 17, 2004 01:41 PM
