Radiator hose
Old Jan 13, 2005 | 03:10 AM
Rostr02's Avatar
Default Radiator hose
Any one know of a aftermarket radiator hose kit for the crx. I am planning a k series swap so keep this in mind it cant be silicone hoses. Any one know of anyone that makes a braided kit. Or does anyone know of a DIY kit i could work with. TIA
Robert
Old Jan 13, 2005 | 08:30 PM
Rostr02's Avatar
Default Re: Radiator hose (Rostr02)
no one wow
Old Jan 14, 2005 | 03:11 AM
Rostr02's Avatar
info?
Old Jan 14, 2005 | 03:15 AM
jc836's Avatar
I seriously doubt you will find anything that is a direct install for a swap using braided lines or even the covering kits. Check with NAPA, Advance or Autozone when you determine the way they need to be shaped and sized-work from the stock ones. BTW: stock Honda hoses are just fine and ther are braid kitsfor them-check Summit, etc.
Old Jan 14, 2005 | 04:18 AM
streetmodified's Avatar
i think you can custom order that kind of stuff from Summit Racing. ??
Old Jan 14, 2005 | 04:27 AM
Rostr02's Avatar
Default Re: (streetmodified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 &raquo;</TD></TR><TR><TD CLASS="quote">I seriously doubt you will find anything that is a direct install for a swap using braided lines or even the covering kits. Check with NAPA, Advance or Autozone when you determine the way they need to be shaped and sized-work from the stock ones. BTW: stock Honda hoses are just fine and ther are braid kitsfor them-check Summit, etc. </TD></TR></TABLE>
thanks Ben
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetmodified &raquo;</TD></TR><TR><TD CLASS="quote">i think you can custom order that kind of stuff from Summit Racing. ?? </TD></TR></TABLE>
thanks Bill
I will have to check summet i did not think they had anything like this
Old Jan 14, 2005 | 11:36 AM
Rostr02's Avatar
Default Re: (Rostr02)
any one know of ant other company that would do this or how about a nice DIY on how to do it?
I know summit offers now I just want other options
Old Jan 14, 2005 | 11:38 AM
DaX's Avatar
DaX
Loved
Community Favorite
I have a crazy upper radiator hose setup due to the turbo manifold I'm running. I ended up buying two GSR upper radiator hoses, cutting them into pieces, then putting them back together.
Modified by DaX at 10:04 PM 1/23/2005
Old Jan 15, 2005 | 01:01 AM
Rostr02's Avatar
Default Re: (DaX)
looks good though I just want to have some stainless lines for the fact my zc coolant lines used to shrink for no reason with a fulll radiator or not. I dont want my k series to suffer like my d series
Old Jan 15, 2005 | 10:24 AM
RCautoworks's Avatar
Look for Earl's Performance Plumbing and you will be set
http://www.holley.com/HiOctn/P....html
Modified by 90blackcrx at 2:06 PM 1/15/2005
Old Jan 15, 2005 | 12:48 PM
dingusjt's Avatar
Default Re: (90blackcrx)
greddy makes the braided hose kit's for b series...maybe something can be rigged.
robbbby
Welding / Fabrication
Dec 4, 2007 09:39 PM
Boostage
Jun 28, 2006 10:15 AM
crxnug
Feb 3, 2006 07:26 PM
wdskuk
12
Jan 24, 2004 09:38 AM
B18EG6
May 5, 2003 11:36 PM
