Anyone replaced vtec solenoid valve filter before?
It's pretty easy, you don't have to drain the oil. When I did it, I changed the following things because it was hard to really tell which one or more was leaking:
#12 is the gasket/screen you're talking about. You might need your VIN because they're not all the same.
#14 is the gasket under the VTEC solenoid valve.
#25 is the O-ring for the VTEC oil pressure switch.
#8 is the cam plug. For this you have to take off the last cam cap...
to continue with JimBlake's answer, if you change the cam plug be sure to change your spark plug grommets and vavle cover gasket.
and like he said, its an easy job.
Master23
17
Apr 1, 2018 08:48 AM
PatrickGSR94
Dec 19, 2014 08:02 AM
thatbluecrx
Feb 2, 2005 11:26 AM
