how much longer my engine will last?
Old Jan 12, 2005 | 09:43 PM
crxtreme27's Avatar
Default how much longer my engine will last?
well i have noticed that my car has been burning quite a bit of oil and well after doing some research i think its the piston rings, i was planning on taking a 2000 mile round trip this spring, is it dangerous to take it?
Old Jan 12, 2005 | 10:12 PM
PrettyLude's Avatar
do a compression and leakdown test
Old Jan 12, 2005 | 10:59 PM
crxtreme27's Avatar
Default Re: (PrettyLude)
i will do a compression test this weekend.. but i never done a leak down test, how do i do it and what tools do i need?
thanks
Old Jan 13, 2005 | 02:09 AM
SlowReaction's Avatar
Default Re: (crxtreme27)
To do a leakdown you'll need the tester and access to a air compressor. Any local car parts store should have this. What your doing forcing air into each cylinder while its at tdc, the gauge on the tester will tell you if your leaking a certain percentage of air that your forcing in. If it is leaking you should be able to hear it come out from somewhere in your motor. Good Luck
02BladeRider
Jul 7, 2017 05:49 AM
dE.fUsEd
Apr 3, 2012 08:58 AM
Poey2
Jul 19, 2009 07:38 AM
vteclife
Jun 7, 2008 02:21 PM
