WHy Am I Smoking OUt The Exhaust??
Old Jan 12, 2005 | 09:19 PM
Mischief_EG's Avatar
Default WHy Am I Smoking OUt The Exhaust??
Ok here goes. Ive got a JDM B18c in my hatch with I/H/E with testpipe, no O2 sensors, and rechipped ECU with race program. I burn off the regular amount of oil...maybe half a quart within the oil change time, and compression is good across the board. But still I get this constant smoke coming out of my exhaust...its always there, more when the car is warming up, and less when its at normal running temps. I was just wondering if this is "normal smoke" out the exhaust pipe, due to me not having a cat perhaps? Any input would be greatly appreciated. Thanks~
Old Jan 12, 2005 | 09:29 PM
KingJeff's Avatar
Default Re: WHy Am I Smoking OUt The Exhaust?? (Team_MISCHIEF_916)
my car was smoking like crazy a month or 2 ago. THe whole street was covered with smoke. FIgured out I put way too much oil in my car
Old Jan 12, 2005 | 09:30 PM
SiR Inspired ED7's Avatar
What Color does the smoke look like?
Old Jan 12, 2005 | 09:32 PM
Default Re: WHy Am I Smoking OUt The Exhaust?? (93 DA B16a)
The smoke is white/grey in color...i recently rebuilt the head with new valvetrain, so the headgasket is brand new.
Old Jan 12, 2005 | 09:47 PM
BUmpalicious~
Old Jan 12, 2005 | 09:56 PM
rough_draft's Avatar
Default Re: WHy Am I Smoking OUt The Exhaust?? (Jeff K.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff K. &raquo;</TD></TR><TR><TD CLASS="quote">my car was smoking like crazy a month or 2 ago. THe whole street was covered with smoke. FIgured out I put way too much oil in my car </TD></TR></TABLE>
god thats bad for ur car
Old Jan 12, 2005 | 10:20 PM
rdblckSV650S's Avatar
does the smoke smell sweet at all?
Old Jan 12, 2005 | 11:48 PM
Default Re: WHy Am I Smoking OUt The Exhaust?? (b0b0o7o7)
Smell Sweet? What would that mean?
Old Jan 12, 2005 | 11:59 PM
if it smelled sweet, that would mean you've got a problem with your headgasket, and that you're burning coolant.
Old Jan 13, 2005 | 12:02 AM
Hmm...okay, well my coolant levels are fine, so id ont think that could be it, but i'll check anyways. anybody else?
Old Jan 13, 2005 | 12:29 AM
integrx's Avatar
New User
smoking on the start up? after its been warmed up? does it still smoke when your done driving and you idle? maybe its the cold weather.
Old Jan 13, 2005 | 01:08 AM
aeon's Avatar
mines does the same, it's always smoking. it has been getting cold out, maybe that might be the case. my idle is also screwed up, it's always surging up and down. can this be part of the smoking problem?
Old Jan 13, 2005 | 09:58 PM
Default Re: (aeon)
yea its pretty much smoking all the time...just more when its cold and warming up. i guess if im not losing coolant or any significant amount of oil, everything should be ok right?
Old Jan 13, 2005 | 10:04 PM
notmightydx's Avatar
Default Re: (Team_MISCHIEF_916)
i would have to say yeah! my usdm gsr does the same thing in the colder weather! if all fluid levels are fine it shouldnt be a problem. keep us posted good luck
Old Jan 13, 2005 | 10:09 PM
Default Re: (notmightydx)
Thanks for the help fellas. Ill just keep on checking fluids and see how it goes.
Old Jan 13, 2005 | 10:27 PM
BlueIntegraBoy's Avatar
My car puffs out a cloud once in a while from running too rich
Old Jan 14, 2005 | 01:07 AM
teknoracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team_MISCHIEF_916 &raquo;</TD></TR><TR><TD CLASS="quote">The smoke is white/grey in color...i recently rebuilt the head with new valvetrain, so the headgasket is brand new.</TD></TR></TABLE>
Any updates??
Old Jan 14, 2005 | 02:21 AM
integrx's Avatar
New User
its also the whole exhaust system...no cat
Old Jan 14, 2005 | 05:44 AM
Danziver's Avatar
Default Re: WHy Am I Smoking OUt The Exhaust?? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">My car puffs out a cloud once in a while from running too rich</TD></TR></TABLE>
Mine too i think that this is your problem. Mine smokes in this cold weather on warm up but stops after I start driving and im running rich too. If all of your fluid levels are ok, the i dont think its a problem.
Old Jan 14, 2005 | 01:20 PM
yee SERIOUS's Avatar
bent sugar smell means you have a leaking headgasket and you're burning coolant.
if you see some blue smoke with your white and gray. then you might have an oil leak somewhere and it's being burnt. my friend had this problem. he just traded his car in for an IS300.
how long ago did this start? if it was just in the winter time, then it might just be the climate change.
Old Jan 14, 2005 | 04:29 PM
mkiv98's Avatar
Default Re: (LiTtOGPiMp)
check your power steering. had that problem in a 94 supra and 91 supra. power steering fluid...smelled like **** and pissed people off, white like you said
Old Jan 14, 2005 | 05:57 PM
Quiks66's Avatar
Default Re: (mkiv98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkiv98 &raquo;</TD></TR><TR><TD CLASS="quote">check your power steering. had that problem in a 94 supra and 91 supra. power steering fluid...smelled like **** and pissed people off, white like you said</TD></TR></TABLE>
For some reason I highly doubt that power steering fluid is the cause of all the smoke. The last time I checked, power steering fluid does not cycle through the motor at all, like oil and coolant do. Uhhh...
Old Jan 14, 2005 | 06:31 PM
Default Re: (Quiks66)
it has always smoked ever since i dropped the motor in my hatch (about 5 months ago)...fluid levels seem to be okay as of right now...for sure its not power steering cause i dont have it...
im running a bit rich for sure, still no cat and the chipped ecu eliminated the need for an o2, so I pulled the sensor and plugged up the hole...maybe this could have something to do with it?
Old Jan 15, 2005 | 08:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quiks66 &raquo;</TD></TR><TR><TD CLASS="quote">
For some reason I highly doubt that power steering fluid is the cause of all the smoke. The last time I checked, power steering fluid does not cycle through the motor at all, like oil and coolant do. Uhhh... </TD></TR></TABLE>
hmm...when my cousin's speed sensor went bad, he saw power steering liquid around it?
Old Jan 15, 2005 | 09:35 AM
hadehatch's Avatar
are you sure its not just condensation... White "smoke" could be condensation from the exhaust evaporating.
Edit: I just saw that you're in CA so thats probably not it..
