Suspension & Brakes Theory, alignment, spring rates....
Preloading Omnipower Coilovers?
Old Jan 12, 2005 | 08:38 PM
F.U.D.'s Avatar
Default Preloading Omnipower Coilovers?
all this talk about preloading but i dont know what that intails. can someone fill me in?
thank you
Old Jan 13, 2005 | 01:38 AM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
Default Re: Preloading Omnipower Coilovers? (F.U.D.)
basically dont tighten down the top of the shock before you install (the 19mm nut on top)
raise the spring perches until the springs are snug against the top of the shock tower, and then install the coilovers.
Set to the desired height, and then tighten down the top of the shock.
Old Jan 13, 2005 | 05:17 AM
.RJ's Avatar
.RJ
Default Re: Preloading Omnipower Coilovers? (9krpm)
The upper nut has nothing to do with spring preloading!
What preloading is, is putting a load on the spring while its unloaded - tightening the spring perch so that the spring is compressed some while the suspension is unloaded - I'd not recommend doing this, and having the perch just tight enough to keep the spring against the upper hat when the suspension is unloaded (like on jackstands).
Old Jan 13, 2005 | 05:21 AM
t0p_sh0tta's Avatar
Default Re: Preloading Omnipower Coilovers? (.RJ)
What is the purpose of preloading?
Old Jan 13, 2005 | 06:24 AM
9krpm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">The upper nut has nothing to do with spring preloading!
What preloading is, is putting a load on the spring while its unloaded - tightening the spring perch so that the spring is compressed some while the suspension is unloaded - I'd not recommend doing this, and having the perch just tight enough to keep the spring against the upper hat when the suspension is unloaded (like on jackstands).</TD></TR></TABLE>
That is exactly what it says to do in his directions. I said that because thats what I did when I installed his coilovers following the directions that came w/ the coilovers.
Old Jan 13, 2005 | 06:43 AM
9krpm's Avatar
Old Jan 13, 2005 | 06:54 AM
yellowturbo's Avatar
damn just read the instructions... it cant be more clear !!!!!!!
Old Jan 13, 2005 | 07:07 AM
.RJ's Avatar
.RJ
Default Re: (yellowturbo)
wtfh?
Old Jan 13, 2005 | 07:18 AM
9krpm's Avatar
Default Re: (.RJ)
thats what the directions say.
Old Jan 13, 2005 | 07:30 AM
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">damn just read the instructions... it cant be more clear !!!!!!! </TD></TR></TABLE>
Old Jan 13, 2005 | 01:16 PM
F.U.D.'s Avatar
thank you for posting the directions. i bought mine from a private party and i didnt get instructions
1320fuel.com
Jan 21, 2014 03:04 PM
Midori Green
Mar 4, 2008 11:01 PM
m1northreat
Suspension & Brakes
May 5, 2007 01:01 PM
JDM PRO
Apr 2, 2004 12:06 PM
