How can I get P/S back?
Old Jan 12, 2005 | 08:08 PM
Targa4Life's Avatar
Default How can I get P/S back?
I have an LS/VTEC and I dont know what kind of Power steering pump brackets I need to get back power steering. If anyone knows please help me, its a bitch to steer my car. Block is a B18B1 and the head is a JDM B16A. Driving a 95 RS
Old Jan 13, 2005 | 10:52 AM
Targa4Life's Avatar
Default Re: How can I get P/S back? (Targa4Life)
Anyone?
Old Jan 13, 2005 | 12:27 PM
big-junk's Avatar
hears a different way to look at it what part of the motor does the bracket mount too if it mounts to the block then get one for the b18b
Old Jan 13, 2005 | 07:43 PM
Targa4Life's Avatar
Default Re: How can I get P/S back? (big-junk)
The brackets are attached to both the head and the block. So...... They are not lining up. The b16a brackets dont work nor do the b18b brackets.
Old Jan 20, 2005 | 11:18 AM
Targa4Life's Avatar
Can anyone help me? im begining to get neck pains.
Old Jan 20, 2005 | 12:10 PM
jdmotorsports's Avatar
the brackets on my cr-v are only on the block. so i would say get the crv or integra brackets and try those. the integra ones would probably work best, though they look identical between the teg and crv
Old Jan 20, 2005 | 12:14 PM
Targa4Life's Avatar
Default Re: How can I get P/S back? (jdmotorsports)
They will fit... but when you put the P/S pump back on then it does'nt line up with the crank pulley at all. Anyway if noone figures it out or knows what will work then I will simply have to get one made.
Old Jan 20, 2005 | 12:15 PM
what do you mean doesnt line up? if your using crv brackets and crv pulley it should line up. are you using a different crank pulley?
Old Jan 24, 2005 | 03:26 PM
Targa4Life's Avatar
I tried using the stock integra LS bracketry but where the Vtec head is taller than the stock ls head then the brackets would'nt fit so then I tried using the ones off a b16a head but the power steering pump ends up being on a 5 degree slant. So is there a certain combonation of brackets im supposed to use or something. ......... did anyone else have this same problem when they built a Ls/Vtec or am I jinxed?
rorik
Dec 29, 2007 07:13 PM
callinthe187
Nov 11, 2005 07:36 AM
tcr03
Nov 16, 2004 08:31 PM
dohcvtecek4us
Sep 5, 2003 05:15 PM
