b16a2 swap into '94 DEL SOL PLEASE HELP
Drop in with these fixes...
- timing side mounts or mount???? (i'm unclear on what to do here especially)
- need passenger right side front mount
- need driver side ac mount from del sol to keep ac
- reuse old top of transmission mount
- need rear transmission mount bracket, reuse old rubber mount on vehicle
if someone could tell me if i'm correct so i know what to buy please post a response, this is greatly appreciated.
Steven
Steven
the rear mount bracket has to be to dohc del sol
integra driver side timing belt mount
front mount of delsol for ac
passenger front mount of integra
tranie mount is the same
Originally Posted by Timmay
you need 94+ GSR mounts all the way around or 94-95 del sol vtec mounts
Here's a post of mine regarding the B16A2 swap into a DX hatch - same applies for your Del Sol:
Sorry if this isn't 100% pertinent to your car, but here goes anyways:
Okay I have some more time to give a better answer to your question now.
First of all mounts:
For the timing cover side mount you will need to get the cast-iron bracket from any 1994-2001 Integra GS-R and also the aluminum mount as well. You can use the mount from a Del Sol VTEC as well, but not the 99-00 mount because it is totally different.
For the rear mount you will need to use a 1994-2001 Integra rear bracket. The actual rubber mount that bolts to the rear subframe can be the stock civic one. Check the 99-00 mount first and see if it will work too though before you go out and buy an Integra one. I used an Integra rear bracket on my fiancee's B16A2 swap in 1999, but the stock 99-00 one might work too.
The topside tranny mount can be the Civic DX one - it is the same thing.
The front mounting brackets need to be from an Integra 1994-2001, but if you want to keep A/C then get the A/C bracket for a Del Sol VTEC model. the actaul mounts that bolt to the underside of the framerails need to be the stock Civic ones.
I would also insert the energy Suspension mount inserts while you've got the mounts out.
For shift linkage ONLY Del Sol VTEC will work in the Del Sol.
Axles can be either the 99-00 Si axles or any 1994-2001 Integra axles. I'd try to get non-ABS ones as they are usually cheaper.
As I stated before I have a B16A2 swap in a 1992 Si hatchback as well as a B18C5 swap in a 1992 CX hatchback.
There are some differences in these swaps even though they are both "OBD2" swaps, and it all has to do with the factory engine harness that each engine comes with.
On the Integra the engine harness is exactly the same as any 1992-1995 Civic, but it just has a few extra sensor plugs, etc.
On the 99-00 Civic Si (B16A2) the engine harness is totally different from the Civic and Integra ones and CANNOT be used in the 1992-1995 Civic.
So what's the solution?
There are two ways that you can make the B16A2 swap very easy. One way makes it nearly plug and play, while the other requires a bit more work, but you could save some money in the process and it's still not hard at all.
Method number one:
Find any 1996-2001 Integra engine harness. Ideally it should be a GS-R or Type R unit, but if all you can find is an LS then it's only a few extra wires. I'd imagine they should not be too hard to come by and will cost probably no more than $100.00-$150.00 used and they are only $350.00 or so brand new from Honda if you need a reference point.
If you can locate the 96-01 engine harness then simply plug it into the engine and drop the engine in. Even though the harness is technically "OBD2" trust me it is a direct plug in for the 1992-1995 Civic on the underhood strut tower harnesses. All you'll need to wire on your 95 Dx is the VTEC solenoid wire and VTEc pressure switch on your car's chassis harness from the plugs on the shock towers through the firewall, and into the ECU pins. I'll get to those pins in a minute.
What ever you decide you should ditch the 99-00 Si ECU. It is OBD2 and horrible. What you'll need to run is a re-chipped P28 (1992-1995 SOHC VTEC ECU) from Kenji Plennert in Florida. His e-mail adress is kenji211@tampabay.rr.com - tell him Tom sent you from H-T. I run his ECU on my Type R swap and it is way better than any stock OBD2 crap ECU. Even if you wanted to keep the 99-00 ECU you'd need to buy a jumper harness and wire up all of that extra OBD2 bullshit, which is not necessary.
If you run that re-chipped P28 and the 96-01 Integra harness then the swap is almost 100% plug and play. Hell in your Civic DX it will be nearly plug and play if you find a GS-R or Type R harness. You'll only need to wire up the VTEC solenoid and VTEc oil pressure switch if you run a rechipped P28. I'll post pin-outs ASAP.
Actually I just recalled that you will have to only do one thing wiringwise. Simply extend the two wires foir the intake air temperature sensor. For some reason the B16A2 is the only B motor that I know od that locates its IAT sensor into the actual intake tubing rather than the intake manifold itself. for this reason you must simply extend the existing two wires for that sensor on the engine harness to stretch from the intake manifold (where it is on the Integra) to whatever intake arm you decide to run.
Method Number Two:
If you are just way too broke to buy a used 96-01 Integra engine harness, you can use your stock Civic harness. It will require more work, but if you don't mind that then you could save some money. I'll go ahead and tell you that if I were you I'd really try to find that Integra engine harness, but here goes anyways.
To use your stock Civic harness you will need to do some minor wiring changes and a few other things. It's not hard and if you just breathe deeply and read this I think you'll find it to be prety easy actually. I used this method back in 1999 when I put a B16A2 into my fiancee's car, and I did not know that the 96-01 Integra harness would make it near plug and play.
Change #1:
First of all there will be a minor difference in the plug style on the distributor. Some people will say :"get an OBD1 distributor" but they must think that OBD1 distributors are cheap or easy to find used. The B16A2 distributor will have one big plug on it, while your stock Civic and it's engine harness has two plugs. All you have to do is unpin the two lowest fat wires from the B16A2 distributor and repin them into the extra plug on the DX engine harness.
Here's a picture of the B16A2 distributor. The arrows are pointing to the wires you need to unpin. This is a picture of an unaltered B16A2 distributor:
So here's that extra plug on your DX harness with the two wires already ran into it. Notice the wires are the exact same color, making it "idiot proof" so to speak. I'm glad they decided to keep the same colors:
Okay that tales care of that.
Change #2:
The plug on the B16A2 alternator won't plug into your DX harness. There are two ways around this. You could either find an OBD1 B Series distributor, or you can swap the voltage regulator from your DX alternator into the B16A2 housing. The B16A2 will have a square plug while the DX harness will have a round plug. Simply pull both alternators apart and swap the voltage regulator. You'll know which part it is because the plug is part of it. A few 8mm and 10mm bolts are all that stand in your way.
Change #3:
Injectors.
The B16A2 uses OBD2 style injector plugs that will not plug into your DX harness. You can either buy new OBD1 injecotrs for a 1994-1995 Del Sol VTEC or just use your stock Civic DX injectors. I still run the 1992 Civic Si injectors in my fiancee's B16A2 and it dynoed the same or better as any other B16A2 with i/h/e in my area with 143whp with 102 ft-lbs. of torque.
Lastly the pins for the VTEC:
A4 is where you'll pin the wire for the VTEC solenoid
D6 is where you'll pin the VTEC pressure switch
If you cannot find a P28 and you come across an OBD1 P30 B16A ECU you'll only need to add one more wire, which is the knock sensor wire. P28 ECUs don't look for this sensor at all, thus no need to wire it up.
D3 is the pin for the knock sensor
And if A4, D6, and D3 make no sense, here's where they are when looking at your wiring harness on your car where it plugs into the ECU:
As you can see A4 would be on the left most plug, lower row, second from the left.
D6 would be the right most plug, lower row, third from the left.
D3 (probably won't need it) would be the right most plug, top row, second from left.
Does all of this help? Do you need anything else?
Wow that was a collosal waste of time and effort!
So he has an OBD1 SECOND GENERATION JDM B16A, and not a B16A2, eh?
<FONT SIZE="7">****.</FONT>
Disregard everything in my post except for the mounts, linkage, axles info then.
Wiring?
Use your Del sol engine harness on the B16A engine. you might have to wire VTEC depending on what type of Del sol you have then.
Wiring?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iNCU3US »</TD></TR><TR><TD CLASS="quote">its a 1992 DX... So im assuming yes and everything is plug and play?</TD></TR></TABLE>
you need a gsr/or sohc vtec wire harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">
you need a gsr/or sohc vtec wire harness</TD></TR></TABLE>
even his dx harness will work. just have to add all the necessary wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">even his dx harness will work. just have to add all the necessary wires.</TD></TR></TABLE>
yes but scince his car is pre-wired this would be the easiest route, still will have to add the knock wire either way
yes but scince his car is pre-wired this would be the easiest route, still will have to add the knock wire either way</TD></TR></TABLE>
You don't need a knock sensor if you run a chipped P28 ECU.
Boostless-Lude
Jan 14, 2005 07:41 PM
